Question about Whirlpool Washing Machines
My whirlpool washer dryer combo the washer when only on spin cycle squeals
Posted by Leslie Van Ad on
jasbo
  • 2,239 Answers
The drum bearing is seizing or the belt is worn. both are hard to replace. might need to call someone in.
Posted on Jan 28, 2015
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
Posted on Jun 08, 2007
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
The belt is slipping and needs replaced.
Posted on Jan 26, 2008
Anonymous
  • 67 Answers
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
Anonymous
  • 88 Answers
SOURCE: Whirlpool Thin Twin washer/dryer
Check the lid switch, the machine will not spin or drain without the lid switch being activated. You should be able to see if the switch actuator is broken or missing, look in the slot where the lid's plunger drops into, if you can see the gray plastic actuator, set the machine in the spin cycle and try to depress the switch with a flat screwdriver, if it runs, the switch is cracked and needs replaced, if the actuator looks fine, and you can hear a distinct "click" when you press down on it, it may be a problem in the timer, but check the lid switch first, that's most likely the problem.
Posted on Sep 18, 2008
Anonymous
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Any particular problems with installing whirlpool stacker washer/dryer in RV
the main problem is how stable the foundation is for the laundry center when it goes into its spin cycle.
Sep 11, 2012 | Whirlpool LTE5243D Top Load Stacked...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I'VE GOT A WHIRLPOOL STACKING WASHER DRYER COMBO BOUGHT APPROX 2002. wASHER WORKS FINE, pUMPS WATER OUT FINE BUT ON SPIN CYCLE SEEMS OFF BALANCE AND MAKES ALL KIND OF BANGING NOISES. i EVEN TRYED SPIN...
Transmission bearing has failed. The transmission has to be replaced as a unit.
The transmissions are relatively inexpensive (around 150 to 175 dollars) I have replaced 3
of these and they are rather difficult.
Apr 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
93 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
