Question about Tascam Audio Players & Recorders
I have a mixer tascam tm-d4000 and stopped working now screen shows "fatal error" can you tell me how to fix it please
Posted by Josvin Mejia on
Gil Shultz
  • Tascam Master
  • 3,388 Answers
Do you have the service manual and the necessary tools and experience? If not take it to a service shop it will be more cost effective.
Posted on Jan 28, 2015
1helpful
I have mixer tascam tm-d4000 stopped working now shows on the screen "fatal error" what I have to do
I'd suggest flashing the onboard CMOS and check for updates. A fatal error is usually caused by corrupted programming on these units. If you're not comfortable flashing the CMOS I'd suggest taking this unit to a service and repair professional.
Flashing the CMOS is relatively easy. Take off the bottom cover and you'll see a ton of wires and a control board and the back end to the main computer unit. Open the secondary case up and look for a watch battery on board. Pop it out and let the unit sit for awhile (10 minutes to an hour). This is usually a good time to buy a replacement battery. Once you've got the new battery pop it back in and it should brought the unit back to a factory reset state. Any stored programs will have to be reprogrammed but the unit should work. If you still get a fatal error it might suggest hardware failure. Some of the newer models of the Tascam series mixers (including submodels of the TS4000 series) have a hardware diagnostic that is available, while some of the simpler units just give you their version of a blue screen of death. Which could indicate anything from a lose connection and an error reading a subcontrol, to a blown capacitor, blown fuse, short circuit. If it's still under warranty I'd speak to the manufacturer about getting it repaired. They might also offer more sufficient troubleshooting over the phone for your issue.
I do believe there is a factory reset button code you can also try for this unit, but in my experience this doesn't really clear the memory and reset the unit properly. It's like a warm reset instead of a proper reset.
1helpful
Hi I have a tascam tm-d4000 it stopped working now shows on the screen "fatal error"
Usually, this is a symptom of a main board failure. Sometimes rebooting the mixer will temporarily stop the error. If there are any additional numbers (like 99-00000009-00) in the error message, you can try resetting the unit. Press and hold Shift and Mixer Position and then turn on the Mixer. The unit will need to be professionally serviced or replaced. Since it is a discontinued model, check your warranty. It may be cheaper to replace the mixer.
I wish that I had better news for you.
1helpful
How do I initialize the SRAM in my tascam tm-d4000? and How do i fix my 99-00000009-00 fatal error on my tascam tm-d4000?
if you keep Shift+Fader position pressed while turning the TMD4000 on, it will boot in Diagnostics Mode where you will find a menu to reset to factory default, and many more options,...hoping to be helpfull
I have a Tascam TM-D1000 digital mixer that has a TDIF output and want to connect this to my computer. Do I need a PCI 822 card or is there another option to connect?
I have a TMD1000 connected to my computer via the RCA ( Red & White) outputs on the mixer to an M-Audio 2496 Sound card in the computer.
also via the Digital out on the mixer to Digital in connector on the card.
I then edit recordings on the computer with Cubase pro.
My main computer has stopped working. it is displaying a fatal error blue screen with code numbers at the bottom these seems to be problems with the registary stop: 0x00000024 (0x00190203,0x807ae0b0,...
BSOD - blue screen of death....sorry mate but its seems that a fatal error on your operating system occured....most probably a sure way to fix this is to re-install windows, and lose everything on the hard drive...
1helpful
2answers
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
2helpful
6answers
Java (TM) Plug-in fatal error
To view this page curectly intall java virtual machine pc destop of window xp operative system.
4helpful
2answers
Tascam DM-24 Digital Mixer Problem
I purchased a used Tascam DM-24 mixer about 2 years ago, and it 's been running great. Just about 2 months, it frequently shut itself off with a message:
" Power Supply voltage (+5V) is too low for stable operation. Please restart DM-24".
Of course, many attempts of restarting the board, but it won't turn back on after several hours later, and only lasts about half a day work only. Very frustrating. Any idea I could get help or fixed? million thanks for suggestions. Brian
Top Tascam Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
