Question about Denon AVR-E400 - 7.1 Network Home Theater Receiver
How do i get all 5 speakers to work? only the three front ones work not two in back
Posted by George Daher on
getmorepc
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Check the source, is it a surround sound source? If not, you'll need to change it to a 5/7 channel stereo setting, probably under the music option. Most music is only stereo, because we only have two ears!
Posted on Jan 27, 2015
My Edifier M1360 speakers will only work when plugged into the headphone jack and I can't get all three speakers working at the same time. What can I do?
the sub woofer green 1/8 inch plug goes into the audio card either the front or the back of the pc. the jack it plug into is normally the green one. the two speakers normally join together on one card and plug into the subwoofer. also look for a on/off know to the speakers for power. normally on one of the little speakers. make sure it is on.
Nov 09, 2014 | Edifier M1360 2.1 Multimedia Speaker...
Please send me a diagram of how the wiring is to be set up on the back of the speakers
The red connector on the speaker should be connected to the Pos.(+) connection on the Receiver/Amp. The Black to the Neg. (-) connection. ( for the proper speaker) Front Left, Front Right,etc. All, or most paired wire has either a black stripe,different shape on one,or different colour wire(silver/copper) So if you hook up the Blk striped or silver to the Neg.(black terminal) on the speaker, do so at the other end (receiver ) If both speakers aren't hooked up the same, they will work, but there won't be as much Bass because the speakers will be out of phase.(when one speaker cone is moving out,the other will be moving inward.
Dec 03, 2011 | KEF Audio Model Three Main / Stereo...
How can I replace a tweeter for a 10 year old Cambridge Soundworks tower 2 speaker?
Its pretty simple actually.
If you already have the same size new tweeter. You take off of course the large felt cover so speakers are exposed on front. Just like your picture is in this post. Then you should see some screws, most likely it is going to be Phillips. Then unscrew all the screws, the whole front should slide out with of course speakers still attached, don't pull out to fast or far, to make sure the internal wires are long enough to take whole front out and set aside speaker box, the on back of speaker should be two wires going to it, maybe three if is tapped in conjunction with a ground. Anyway on back of speaker unplug the wire from speaker and then, take out screws which is normally on back of speaker, pull speaker out, put new one in and repeat steps in reverse order. Hope this helps. Mike
Jul 07, 2011 | Cambridge Soundworks Tower II Speaker
I just brought some wharfedale one-three speakers and have them hooked up as the rear speakers. Can i get the sub to play still and do i hook the speaker wires in the top or bottom?
Do you mean "Modus 13"?
See picture 6...
http://www.freeads.co.uk/uk/av/audio/hi-fi/speakers/8402337/wharfedale-modus-one-three-speakers-black-rare-bi-wire-quality/view
Put the jumpers back in as shown. Hook your speaker leads to either top or bottom. The entire array of drivers will be active.
Make your receiver aware they are LARGE for the purposes of bass reproduction so some bass will get out to them. FYI, many AVR's will only allow Large Rear speaker selection if you also have Large Fronts. Refer to the manual(s).
Mar 07, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
Radio comes on --but speakers do not works
Check your three position switch on the dash.
One position is front speakers - one is both front and back and one is helmet only
Aug 31, 2009 | 2002 Harley Davidson FLHTCUI Electra Glide...
Two of four speakers are not working...one each in front and back of car
then the ones not working r probably ran together pull out radio and check speaker wire connections,if that doesnt work run the back speaker off the other back speaker , then do same w front , or if that doesnt work maybe speakers r blown out ,
Jun 27, 2009 | Aiwa CDC-X204 CD Player
Bose Lifestyle 20 system. sound from only two speaker
A lifestyle 20 system is stereo only. Two channels. Left and right.
Jun 04, 2009 | Bose Lifestyle 20 System
Put in new front speaker in car and they worked good for a couple of hours, now there is no sound from the front or back speakers. I unhooked the front speakers and put one back then rear speakers worked...
Hello. Sounds like the amplifier is damaged and or could be a short from a front speaker wire to the car chassie ground. Assuming that the four speakers are driven by the same deck. I would first varify that the amplifier in the deck (radio, CD, etc) is functioning properly if it is being used.
Jan 21, 2009 | Car Audio & Video
No sound, cenral and rear speakers Dell 5650 speakers
the surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Jan 20, 2009 | Dell 5650 Computer Speakers
My three front speakers stoped working
Ob
viously something reset itself. Do a systerm restore back to a date when everything was working--that should fix you up simplest.
Nov 01, 2007 | Logitech Z-5300 Computer Speakers
Denon AVR-E400 - 7.1 Network Home Theater Receiver Logo
98 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
