I have a Garrison electric portable heater which shows a code FF. What does code FF mean? Thanks in advance.
I am unsure of model number. All I can tell you it is a small portable electric heater which worked fine and now shows a code FF.
Posted by Austin Alexander on
cwradio73
  • 1,162 Answers
You might want to check with Garrison, there was a recall on some models last year. It might be worth your time.
Posted on Jan 27, 2015
Manual for garrison oil heater model #043-5863-4
You should be able to download a manual here:
garrison oil filled heater model 043 5863 4
Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
Nov 16, 2016 | Heating & Cooling
Code ff on portable electric heater. What does code ff mean
If its a Sunbeam you need to check the electric cord an make sure it is plugged into heater an wall socket well. Really need brand an model to help more.
Jan 27, 2015 | Refrigerators
Why doesn't heater heat up when turned on ?
  • I bought 3 convection heater ( model 052-2026 ) .Two of them stop to heat after 2 years using . The third, stop to heat last december. Canadian Tire ( store where I bougt the product ) told me to contact Garrison Company . Now , I want to get refund. Michel L?ger Quebec, Canada
Mar 04, 2014 | QMark Portable Hydronic Electric Baseboard...
This heater is a 2000 watt garrison convection wall mounted heater. the light is on but the heater does'nt heat up
The heater is disconnected or there is a damaged wire. You can try to open it up or bring it in. I would suggest bringing it in for repairs.
Elisa Jed ' http://www.encoremec.com/about
I need a Manual for Garrison Portable Air Conditionner 9000 BTU model 043-5486-2.
I have a Garrison 3-1 air conditioner and it's not working it's showing me H8 on the display what does that mean????
May 05, 2013 | Heating & Cooling
Manual for a Garrison Portable air conditioner
I have uploaded the manual for my model 5440 (3-in-1) here: Garrison 5440 Owner Manual
Jun 16, 2012 | Heating & Cooling
My water heater error code 1 model ee3250rd055v what does this mean
Water heater is not 100% identified.
Unknown if this is gas or electric heater.
Problem posted under Whirlpool water heaters typically made by American water heater company.
Call Whirlpool 877-817-6750.
They will ask for model number and serial number located on label on side of tank.
Call is answered in USA by trained person who can answer specifics about that model, including warranty, age, regular maintenance, error codes, and possible solution for that specific model and serial number.
I have found these folks to be helpful.
Whirlpool manuals do not show that specific model:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
If you have the energy smart electric water heater with electronic control board, then error code explanation shows on the control board. Error 1 or a single flash, is start-up failure and requires tank to be full of water. Read page 10 of manual. Make sure water heater is full of water and water is coming full stream out of tub spout before turning on power. Also disconnect power from unit, make sure water heater is full, and then reconnect power to see if unit resets.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
http://www.whirlpoolwaterheaters.com/downloads/6510306.pdf
Sep 12, 2011 | Whirlpool Water Heaters
Our refrigerator constanly has ER FF in the ice & water display area. What does that code mean.
This error code ER FF indicates a problem with the evaporator fan motor but it can also be with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. But resetting the board does not solve the problem always. The Defrost Control Board being defective will also show this error. The best solution would be to look for your complete model number and contact me HERE and I will send you your models Service Manual and parts to look for, I will continue to publish manuals HERE, Thanks, Sea Breeze
Feb 20, 2011 | LG Refrigerators
Heating & Cooling Logo
422 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
