Question about Refrigerators
Code ff on portable electric heater. What does code ff mean
I get code ff on the heater. what does ff mean?
Posted by Austin Alexander on
cwradio73
  • 1,162 Answers
If its a Sunbeam you need to check the electric cord an make sure it is plugged into heater an wall socket well. Really need brand an model to help more.
Posted on Jan 27, 2015
What does ff error mean
For LG A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
Jan 06, 2018 | Refrigerators
I have a Garrison electric portable heater which shows a code FF. What does code FF mean? Thanks in advance.
You might want to check with Garrison, there was a recall on some models last year. It might be worth your time.
Jan 27, 2015 | Heating & Cooling
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Code FF on a Proform 695 LT
Upper electronics have failed and will need replaced depending on how much you spent on the unit it may not be worth it. Go on iconfitness.com website go to customer service then replacement parts input manufacturer then Model Name
Apr 23, 2010 | Exercise & Fitness
I have an ep-8kta3+pro m/board. Occasionally it fails to start up and the LEDs are stuck on FF. What does the code FF mean?
FF mean kind for computer geeks Fatal Failure meaning the only solution is geting a new one thanks and good luck
Oct 20, 2009 | EPoX EP-8KTA3+ Pro Motherboard
Control says FF?
What control, brand, model # etc.? An educated guess would be that you have a gas forced air system. FF would typically mean Flame Failure. Pull flame sensor, clean rod with steel wool until shiny again and reinstall. Your flame sensor will have one wire going to it. Located at the opposite side from the igniter. It will have a ceramic base with stainless steel probe protruding into the flame. Hope my guess helps.
Oct 07, 2009 | Sunbeam 722 Auto Shut-Off Heating Pad...
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
