Question about Samsung 65" F9000 Series 4K Ultra HD Smart LED TV
How do I watch 3D movies on Samsung 4K tv connecting external hard disk
Connected external hard disk but could not watch 3 D movie recorded on it
Posted by Antubhai Mehta on
5 Related Answers
Merkader
Merkader
  • 21 Answers
SOURCE: no colour when dvd player connected to tv
I would try a different set of cables to hook up the dvd player, sounds like you either have bad wires or bad ports on either the tv or dvd player. Test each and see which one it is, hopefully it's only a set of cables.
Posted on May 05, 2008
Mike Waldron
  • 1019 Answers
SOURCE: dv device is not connected
DV is a digital device, used for digital Cameras.
Have you got the cabling correct ?
alternatively, try tuning the dv device into a television channel, or vice-versa.
Mike @ compurepair.
Posted on Nov 05, 2008
Paul Hutchinson
  • 909 Answers
SOURCE: no signal from samsung dvd-vr375 and tv
That means the dvd (I assume you meant dvd not vcr) needs tuning to the stations. Press menu, then select the tool box icon(or setup) and select the tuning option. Select auto tune and press go(centre button).
Give it a few minutes to tune in and away you go.
Posted on Jan 02, 2010
Anonymous
  • 74 Answers
SOURCE: Super writemaster slim external dvd writer can not
You need to install a DVD Player for that. For example you can get VLC media player from here and watch DVD-s.
Posted on Jun 25, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Hello, I have the samsung HD-T
I think you mean HT-D5500 Home Cinema. You can't play fast and loose with those details.
The manual and other support is available here...
http://www.samsung.com/us/support/owners/product/HT-D5500/ZA
See page 38 and read about Audio Sync.
Theory:
http://en.wikipedia.org/wiki/Audio_to_video_synchronization
Posted on Jun 18, 2011
How do I transfer recorded movies to a external hard drive?
That depends. What device did you use to record these movies? If you recorded a movie using a DVD recorder, connect your external hard drive to a PC device which has a DVD rom. Go into the files, copy and past the file to your external drive.
Sep 15, 2016 | Hard Computers & Internet
How do I play movies from my external hard drive connected by USB to my MX android TV box.?
The TV should support the file system to read the directory structure of the Hard disk and also the the file type to read the video file. Try mpeg / jpeg file on a thumb drive on the same USB port.
Nov 06, 2014 | Televison & Video
I want to copy an external hard-disk's HD contents onto a Panasonic Blu Ray Recorder
You have to search on internet for drivers which can support your computer and your Panasonic recorder. If this cannot help you to solve the issue, then you have to get help from your friends or relatives who have a different laptop from your laptop or computer. You can download those drivers in your hard drive and install in your computer.
Mar 13, 2014 | Computers & Internet
Acer external hard drive ah022s usb3.0 not detected
Try to connect it on another usb port, or another PC to make sure that it's not your usb or PC's fault. If nothing happens, turn it off, disconnect the cables,power source and usb, reconnect them, and turn it on.
Good luck.
Feb 12, 2014 | Computers & Internet
No espace on the disk
hi, with some dvrs you can, with the usb connect on the front, an external hard drive. then move recordings to it. also replacing the harddrive inside will give more space, but if its a leased unit, no chance of that. my solution to it has been record everything i can stand to watch in standard def, like kids shows and such, and only in high def sports and movies, saves a lot of space!
good luck!
Jan 31, 2011 | RCA Televison & Video
External Hard Drive
If you plan to store movies on the HD, better buying a 1TB hard drive. WD Mybook is one of the best external HD.
To rip and store DVD movies into the hard disk you will need a specific software, like the ones below.
DVD Converter - convert DVD video to AVI/MPEG/DIVX files
Freeware converts DVD AVI MPEG WMV RM to MP3 or iPod Video
Movie2x Freeware DVD Converter Download
DVDx (freeware from labDV)
Jul 28, 2009 | Western Digital My Book Essential Edition...
Cannnot find movie recorded previously
I recorded a movie, viewed it and when I tried to see it in my TV by mistake I closed screen and the index view was gone. I opened the screen and the following message came :
Movie recording disabled
Sep 16, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
When I try and record is just keeps saying movie recording disabled, it also flashes a yellow symbol
Aug 10, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
DV-PC recorder
DV-PC Recorder is a Windows XP only application that enables you to record images and sound on the tape in the camcorder and on the computer's hard disk by connecting a camcorder equipped with the DV CONTROL function to a computer using an IEEE1394 (DV) cable. DV-PC Recorder has the following features. 1. You can record movies simultaneously on your computer's hard disk and on the tape by pressing the start/stop button on the camcorder. 2. It enables long, continuous recordings, which you cannot achieve with the tape alone. (Approximately four and a half hour's worth of recording will fit on a 60GB hard disk.) 3. You can start editing the movies on the computer right after recording, as the images and sound are saved on the computer's hard disk. (Optional editing software is required to edit movies) 4. You can record movies on the tape in the camcorder and on the computer's hard disk by controlling the DV-PC Recorder from your computer.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Samsung 65" F9000 Series 4K Ultra HD Smart LED TV Logo
199 people viewed this question
Top Samsung Car Audio & Video Experts
Marvin
Marvin
Vernon Taylor
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
