Question about Philips Aj 3540 Big Display Clock Radio
How do I get the battery to operate the clock when the power is off. I have the battery in correctly, but when the power is off the clock goes off?
Posted by Brian Hansen on
cwradio73
  • 1,162 Answers
I just read the manual an I am not sure it does. The manual says nothing about that. My clock does the same when power fails. Comes back to correct time when power returns. I miss that on my older clock. Display never went out even during power outage. You can call Phillips an ask or email. It is on there site.
Posted on Jan 27, 2015
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
Wall scoreboard clock model #0028 not working after outlet blew
Remove several screws around perimeter of clock. Open up clock and find small (quarter -sized) battery. Remove this battery - it may be hot glued in place but you need to remove this. You don't have to replace it just remove it. Apparently this battery is used when you have a power outage to retain date / time, but when it goes dead it won't allow the clock to operate. So just remove it and put the clock back together and all should be fine except you will have to reset the date etcetera when you have a power outage.
Jun 09, 2013 | Computers & Internet
How do you get the clock to operate on a battery only (uses a 9V). I insert the battery, then unplug the clock. The display is dark. But when I plug it back in, it is on the right time. If there was a...
They're just used to retain memory. That's all. Once power comes on, the time should be correct. Now if the power went out and there was no battery on the clock, when the power comes back on it goes straight to flashing 1200.
Jun 28, 2011 | Westclox 181961 Omni II Clock Radio
Which the voltage of the transformer to be replaced
Hello
Your clock has a backup battery. Battery is for time backup only.
The clock and alarm memory will
be retained during a power
interruption. During battery
backup operation, the display
will not light up, but the correct
time will be maintained internally
The mains transformer inside it will be of 10.2vAC secondary to 120VAC primary. OK.
May 13, 2011 | GPX CRCD2806 Clock Radio
Orvis wood reel battery clock
Apr 05, 2017 | Home
This AM it started blinking and will not stop It is less than 1 yr.old.
Sorry it took so long to reply to your question. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day
Mar 16, 2008 | Emerson Smartset Clock Radio
Alarm 1 won't go off when set to AM
Sorry it took so long to answer your question about the Clock/Radio. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 19, 2007 | Emerson Smartset Clock Radio
Philips Aj 3540 Big Display Clock Radio Logo
102 people viewed this question
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
