Question about Mitsubishi Televison & Video
We have a Mitsubishi WD-60737 that occasionally turns itself off with a blinking red light (sometimes solid red).
The error code is 17. Sometimes it takes several tries to restart the TV, as it may struggle to start then turn off again with blinking red light. Sometimes when trying to start, there is a pulsating glowing of the black screen, which sometimes results in starting OK, sometimes not. There are periods of months where it turns off only once a day, and periods where it hardly stays on at all. Typically, it will turn off a half hour after first starting, then several more times in the next half hour, then it may stay on for hours and hours. It seems it may work better after we return from a vacation of a few weeks. We had an impression it is worse in the winter months, but not sure. We have replaced the main PWD power board and it did not help.
  • simonbaker4 Jan 31, 2015
    Thanks for all the suggestions and additional comments from other owners. This is what I have found so far: In reviewing the meaning of code 17, I the manual indicates:
    Description: Communication loss, TV Micro - Engine (3.3V-ENG-SDA & SCL)
    Likely causes: Loss of 12V from PWB-POWER to Engine
    (Loose PE or PE2 connector).
    Engine Failure
    Since it doesn't cost anything, I located the PE2 connector and, although seemingly solid, I plugged it in and out repeatedly to try to clean any corrosion or gaps might have arisen over time. It makes sense marginal connections might be temperature sensitive.
    It didn't fix the problem, so I tried the same thing with the thick black DVI cable, which I assumed carries the "data" (picture and sound) from the main board to the light engine. I repeatedly plugged in and out the connector at both ends of the DVI cable, hoping to make better contacts. I also reseated some of the small cables going to the engine board from the lamp assembly/ballast area.
    (by the way, I had played extensively with the thermal sensor cable many times in the past with no affect).
    Since reseating the DVI cable, we have not seen the problem even once! It has been several days now. Before, we could hardly get the set to stay on for a few minutes.
    *** So maybe improving the DVI (or other cable) connections was the solution.
    I can't state yet that the problem is fixed for sure, but early evidence is that reseating the cables made a world of difference.
    In the meantime, I had ordered a whole new light engine module from tristatemodule.com (about $300). Because of the cost of shipping and restocking fee, it would cost me about $100 to return it. I wish there had been more advice on the internet about reseating these cables. Perhaps my problem is unique and rare. I also wish there was more encouragement on pulling out the main modules from the WD-60737 -- I was too timid to get in there and haul the modules out, but it is really quite easy. I worried the slightest juggling might throw the picture out of focus or alignment some way. But apparently, it is quite robust in that regard.
    We still are using the original lamp (we don't use max brightness settings), the picture looks great, better color/gamma than a Samsung LCD set we were trying out, in my opinion. Somehow the Mitsubishi colors look real and the LCD sets often look too unnatural or too waxy no matter what settings tried.
    I really like the picture on these Mitsubishi DLP sets (I appreciate good cinematography). The downside may be cost of ownership, as bulbs must be replaced and heat may increase maintenance, and also electric bill probably higher than with LCD/LED sets. Also they stink for hooking up a computer because of overscan!!! They don't display the full 1080 x 1920 image, cutting off the margins! Mitsubishi should be sued for that -- there was a big lawsuit years ago for tube computer monitors/TVs advertising tube size rather than viewable size -- how does Mitsubishi get away with it?
    I'd like to edit my previous comment to put in line-spacing which got lost when posted. Actually, I want to post the comment as an answer so others can see it more easily. But this website doesn't let me do it it seems. -SB
    New Friend:
(I'm the original poster, adding my comment again here for visibility)
Likely causes: Loss of 12V from PWB-POWER to Engine (Loose PE or PE2 connector). Engine Failure.
It didn't fix the problem, so I tried the same thing with the thick black DVI cable, which I assumed carries the "data" (picture and sound) from the main board to the light engine. I repeatedly plugged in and out the connector at both ends of the DVI cable, hoping to make better contacts. I also reseated some of the small cables going to the engine board from the lamp assembly/ballast area. (by the way, I had played extensively with the thermal sensor cable many times in the past with no affect).
Anyway, hope this might help some other owners.
-S
Posted on Jan 31, 2015
    To clarify: Sam Adams/simonbaker are both me, just needed to accounts to be able to post an answer to my own question.
    I meant "two" accounts.
    Filmmaker:
    Uploaded 5 video answers.
  • 181 Answers
Hello, have you changed the lamp? and if you did, did you use an original Mitsubishi lamp?......tks
Testimonial: "I mistakenly voted helpful, but meant not helpful, for this suggestion:I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board. The origin question stated that a new power supply board had already been put in with no improvement."
5 Suggested Answers
Anonymous
SOURCE: TV shuts off automatically
Posted on Oct 31, 2007
Anonymous
  • 64 Answers
SOURCE: Mitsubishi TV #WS 5531 hd 1080 upgradable - Screen
Most likely burned out lamp.
Posted on Aug 11, 2009
Anonymous
SOURCE: problems turning my tv on, need to try several times
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
Posted on Jun 06, 2006
Anonymous
  • 556 Answers
SOURCE: Mitsubishi WD-Y57. tv tries to start green light - no picture
have you checked the lamp?
Posted on Aug 14, 2009
Anonymous
SOURCE: LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Posted on Aug 15, 2009
WD 60737 error code 12 what do i need to do. We replaced bulb and now it just flashes red
Error code 12 is no problem found. I would make sure I had the right bulb, make sure it is seated properly, and make sure the door to the lamp box is on correctly. If that doesn't work, and you still have the old bulb, put it back in. Even if it doesn't work it will display a bad bulb code and not the current one if your new bulb is incompatible. Sometimes that happens when you get a new bulb with incompatible specs.
Sep 11, 2016 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi wd-60737 won't turn on just flashes red I get error code 12
Hm Code 12 is "no error". Which is odd since you have an error.
However, since the age of the TV is around 7 years, you may have the problem that the power supply is known for. The capacitors in the power supply fail.
To be safe, check the lamp and make sure its in good order. May want to change it anyway if its more than a year or 2.
Sep 10, 2016 | Mitsubishi WD-60737 TV
Blinking code 3 2. will not turn on
error code 32 indicates the lamp cover is open, you might also check that lamp cover switch.
Mar 15, 2015 | Mitsubishi WD-60737 TV
It will not come on with a blinking yellow light and a code of 3 green and 2 green blinking lights.
Error code 32 indicates lamp cover open, also check the lamp cover switch
Mar 14, 2015 | Mitsubishi WD-60737 TV
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi wd-60737 fan problems
i have the same tv i replaced the lamp n now its a oange blinking light on
Feb 27, 2014 | Mitsubishi WD-60737 TV
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
What is the red light on my wd-60737 mean?
You can Google the brand and model number for a free owner manual but on the set indicated it means usually the lamp is the issue.
Mar 27, 2012 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi DLP - WD-60737 - 1 year old I have sound but no picture. The lamp is not lighting up. I have already replaced the lamp. After I replaced it, the set worked fine for a couple of hours, but is...
This tv has self diagnostic feature that will show last error through front light blinks, there is procedure to activate and read out error code to diagnose problem section of tv to solve its issue so to get tv back in business.
Let me know to proceed.
Thanks.
Mar 03, 2011 | Mitsubishi WD-60737 60 in. HDTV
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
