Use passenger door to for key entry.tried to ground out alarm wires,priced rekeying from salvage yard,locksmith also seemes to high prce to take apart door lock said he can make a key but it wont function unless its chipped,drove it in 911 only cases and left unlocked,
SOURCE: After alarm goes off, all electrical works except car won't start
hi there
from what it sounds to me is that the alarm is still in anit theft mode
i had this happen to my vehicle
one thing you can try is lock all the doors try and unlock from the passenger side make sure that all the lock come up to the top where they should be
then try it
if that does not work then lift up the rear of the car like it was being towed and it should reset the alarm
short of that you will have to have alarm shop come to you
don
SOURCE: The clicker will not lock or unlock the front
It sounds like your remote needs a new battery.
Your user manual should tell you what type... else, remove the old battery and find an equivalent.
Hope this helps... Good luck.
SOURCE: 1990 lexus ls 400 security system went off now
Okay you may want to check to see if the sensor on door lock cylinder hasn't fallen off from the lock itself. Pull of the door panels and check the wires at the door lock cylinder. Hope this helps.
SOURCE: car alarm went off while unlocking the door, now
you need to reset alarm/immobiliser.lock car with remote, hold button down for 30 secs,then press/hold down unlock button,should reset.another way is with key in ignition/turned on, press alarm button down and hold for 30 secs.this resets immobiliser.toyota
systems vary..depending on market.
SOURCE: I have a 2003 Lexus
A seized up door lock actuator. You can try freeing it up by spraying a good penetrating oil, my favorite is PB Blaster. If it wont free up you will need to replace it.
