Question about Pen Drive IVO MP3 Player
On inserting the pen drive,its showing that no disk is inserted into H drive.And on seeing the properties of the pen drive,its showing Zero MB free and Zero MB in use.Its not even being formatted or scanned. What i need to do?
  • Anonymous May 11, 2010
    SCAN YOUR PEN DRIVE USING SOME LATEST ANTIVIRUS AND FORMAT IT AS EARLY AS POSSIBLE.
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 02, 2010
My transend pen drive is not working. I am not able to access my pen drive when an error comes it says " Please insert a disk into drive H: " Also i tried to format it and again an error comes it says "...
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you could see a yellow question mark? right click to reinstall drivers or
insert transend pendrive go to control panel administrive tools computer management disk mangement you you can right click select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
Oct 23, 2010 | Computers & Internet
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk please help!
Aug 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My pn drive shows used space & free space is
see if you can format it if not it is bad
Apr 13, 2010 | Transcend (589307) Media
Pen drive cannot open
Please install the usb driver and check again.
Jul 02, 2009 | Electronics - Others
Ttanscaned pen drive problem
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Jan 13, 2009 | Electronics - Others
PEN DRIVE SHOWING 0 FREE SPACE AND ZERO USED SPACE
Hi
Just go to My Computer.right click on Manage.Then click on Disk Management.In the bottom tab you can see your pendrive.click on it get a new partiotion using NTFS.
Nov 28, 2008 | Electronics - Others
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Sep 26, 2007 | Computers & Internet
Pen Drive IVO MP3 Player Logo
Top Pen Drive Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Pen Drive Audio Player and Recorder Expert? Answer questions, earn points and help others
