Just so all can read this - you need to be a little more polite if you need help! What model do you need the error codes for and which error codes do you need the meanings of?Just so all can read this - you need to be a little more polite if you need help! What model do you need the error codes for and which error codes do you need the meanings of?
Scan for any stored error codes and check the code discription. If no code is present suspect lack of fuel. Try cleaning fuel filters. If cleanig filters dont solve change the fuel pump
Is the problem interrmittant or comes up every time when you turn the copier on?
You'll need to remove the fuser from the copier and inspect it to see if it is binding up making it difficult for the fuser drive motor to turn it. Lubricate any gears thet are gummed up and not turning well. Pay special attention to the swing plate assy. Also check for frozen bearings,flat spots on lower fuser roller, or anything else that can restrict fuser movement.
If that doesn't fix it - you may need a new motor - but that is almost never the case.
hope this helps
if the temp lights are flashing a tru 5x's The temp sensor may be loose on the front control board. Also check the blue wire as well as the black wire that leads to the heater relay on the front board for melting at the relay.. Als be sure to check if you have any other light flash codes.. NOTE:.. You can get these code discriptions by removing the lid(one screw) and looking on the underside for a discription of the codes and the errors
what is your error code?
