Question about Frymaster Dean Kitchen Appliances - Others
Why wont this one fryer pump oil back throught the filter correctly? We have two, one will pump it properly.. one it will go around the sides and eventually clog the line up we declog it, clean the wh
Best to know detail is this happens to be caused by a tech and there is a dispute going on with them because they consistently leave more problems then they fix. That is why I am looking for an answer elsewhere. We have cleaned everything out we have tried new filters we have tried to order a new pan.... Same results. the oil will seek its way around the corners of the pan where there is a tiny gap. where as the other one we have will pull the whole thing down at once. Self testing we dont see any difference in suction either. What the?
Posted by Robert Sawaryn on
5 Related Answers
Anonymous
SOURCE: black ink not printing properly
The print head may be defective.
Posted on Jan 26, 2007
Anonymous
SOURCE: taking out the oil?
I am almost positive that you will have to lift the whole thing to empty the fryer. It looks as if it is one whole piece.
Posted on Jul 21, 2007
Anonymous
  • 1314 Answers
SOURCE: Avanti W851 Top Load Washer, Self Cleaning Lint Filter
they should be able to order one from any appliance pars store but if not contact avainti here ive worked for them for years most of the time if you contact them they might send you one if not they will get you one http://www.avantiproducts.com/
Posted on Jan 30, 2008
Anonymous
SOURCE: Deep Fryer stopped working.
I had the same problem, but I fixed mine!!!! Make sure that the part with the control panel is locked in. It you just sit it in, it won't come on. You must lock it in on the side.
Posted on Jul 09, 2008
Anonymous
SOURCE: SG-14 backfires when turning on
I seen this problem over and over again, the best and simplest way to fix if to just clean your burners. Removed one by one and get them clean with hot pressure water. Most of the time, this easy and fast job will resolve the problem, and don't forget, get those burners cleaned every 6 mos. It requires a 1/2 in socket.
Posted on Oct 23, 2008
Trouble shoot the filteration fryer sg14 . no oil pumping back in the fryer
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Jun 20, 2018 | Cars & Trucks
Can oil be reused in a deep fryer
Hi there!
Once the oil is saturated, you have to replace it and properly dispose used oil.
If you have an oil filtering machine, you can filter used oil to remove impurities with the use of magnesol.
Regards.
Feb 04, 2013 | GE 168997 Deep Fryer
Frymaster pump and motor
Hi there.
Filter paper may be clogged causing the pump motor to trip-off after the filtration of the second fryer, better scrape off any filtered debris on paper afrte filtering.
Also oil temperature must be at least 250F or above to lessen the load on pump motor as oil with low temperature is thicker than oil with high temperature.
Regards.
Apr 12, 2012 | Frymaster Dean Kitchen Appliances - Others
I have a Wells WVAE-55FS 240 55-lb Ventless Fryer, Basket Lift, Oil Filter, Solid State Controls, 240/3... and the check filter light went on.... how do i check my filter and where is my filter located?...
Hi there!
Your filter may need replacement, that is what the light prompts.
For complete owners manual of your unit, you may visit www.wellsbloomfield.com
Regards.
Sep 04, 2011 | Wells WVAE30F Deep Fryer
Where do you put the fryer powder when yo u filter ? Does it go in the grease before you drain it or can it go on top of the filter
After you have assembled the filtering machineprior to filtering, the powder must be spread evenly on top of the filter paper.Once you drain the oil, let it circulate on filter pan for about 5 minutes so that the powder will mix with oil before pumping it back to the fry tank. The powder helps to prolong the oil life.
Apr 14, 2011 | Pitco Frialator SG14 Deep Fryer
Pitco-matic filter system always getting clogged and won't return grease to fryer
Make sure that the filter system is correctly assembled so that oil impurities wont enter pipes and clog the system.
Apr 14, 2010 | Pitco Frialator SG14 Deep Fryer
Which levers to pull or which vavles to open
Pull whichever of the short yellow one you need, Right or Left...and pullthe red one to devert back to the pots.
Found out on my own....FOR FREE
Jan 05, 2010 | Dean SR14E Deep Fryer
Kitchen Appliances - Others Logo
Top Frymaster Dean Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Paul Carew
Lawrence Oravetz
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
