Question about Bosch Dishwashers
My Bosch dishwasher (SMS63M08AU/12) is giving me a E11 error code. It begins a cycle and then approx 4mins in will start flashing the code. From what I can gather, I believe it may be associated with
My Bosch dishwasher (SMS63M08AU/12) is giving me a E11 error code. It begins a cycle and then approx 4mins in will start flashing the code. From what I can gather, I believe it may be associated with the NTC (thermistor??). Is this a big job??
Posted by Adrian on
Dado
    Master:
  • Bosch Master
  • 509 Answers
E11
NTC thermistor fault.
This error code can be caused by the thermistor or the wiring to it being faulty.
Dado
Posted on Oct 08, 2015
5 Related Answers
Anonymous
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
Anonymous
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Posted on Apr 17, 2008
Jeff Meyer
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Posted on Mar 30, 2009
Anonymous
  • 21 Answers
SOURCE: shv6803uc bosch dishwasher won't stop beeping at
CALL 800 944 2904 THEY WILL WALK YOU THROUGH OTHER WISE OPEN THE DOOR AT END OF CYCLE AND BEEPING WILL STOP
Posted on Jul 20, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: My dishwasher(Bosch) makes sqeeling sound
Welcome to FixYa.
Based on your description " makes squealing sound almost like beeping at the beginning of its cycle "...it is likely to be either the pump impeller or the inlet valve.
With the Bosch built line of dishwasher`s this is a known problem...the carbon ring ( spring ) of the impeller pump seal kit. ( make sure it is indeed a SHU9915UC before ordering parts )
**Most common in units not used regularly, i.e. in a holiday cottage or vacation property, but time to time on daily used as well unfortunately...but also due to the heat from normal wear & tear**
You first must determine which is the source of course. Does the noise begin after filling with water and the pump starts, or does it begin upon the filling of water ?
If it's the valve, make sure the water supply line is completely "open" and if so replace the valve with part #425458
i.e.
If it is the motor wash impeller squeeling It can be remedied by one of two methods, replacing the entire motor & pump assy part # 442548...
i.e.
This retails between $99.00us. to as much as $170.00us. depending where you look. I usually go through "searspartsdirect.com" for about $100us. ( you can also investigate "repairclinic.com" or "appliancepartspros.com" to name a few.
Or if you are mechanically inclined, replacing the pump impeller kit. part # 167085
i.e.
The kit is typically around $50 -$75us, hence it can be cheaper when factoring labour for the complete motor/pump assy.
This is a pretty involved repair to explain, in fact I think it is harder to explain than actually do...but I`ve done many.
If you`d like to provide me with an email address I can attach a file in "pdf" showing you step by step how you can do this without much cost at all really...likely your time will be the greatest expense.
Let me know how you`d like to proceed and I`ll help in whatever manner I can.
Thanks for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Posted on Jan 29, 2011
Testimonial: "we are still carefully listening to the sounds and its timing, we plan to change the impeller soon time permitting and will inform about the results"
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
Dish washer goes through cycle but when finished cold with Code E..09
Bosch Dishwasher Troubleshooting ' Dr. Dishwasher
www.drdishwasher.com/troubleshooting/manufacturer/bosch/
Your Bosch dishwasher can run a test cycle which will quickly go through each ... You can find a list of Bosch dishwasher error codes and their definitions here.
Jul 26, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Sometimes dishwasher completes full cycle, but more often than not it stops after half way of cycle with flashing d14. Machine approx 4 years old and only started within the last month or so. All...
What is the brand name and model of your dishwasher? Different manufacturers can quite often use the same error codes for different faults.
Apr 15, 2011 | Dishwashers
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Display has error code h01 and dishwasher won't run model is SMS63M08AU
h:01 means 1 hour delay. Press the delay button repeatedly to get to h:00 then hit start.
Mar 06, 2011 | Bosch Dishwashers
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
Dishwashers Logo
647 people viewed this question
Top Bosch Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
