Question about Yamaha Electrical Supplies
I have an electric start Gen.wont turn over with key. charged battery still wont turn over. jump it and it turns over ?????
Charging battery still wont turn over with key jump it and it starts
Posted by Lee camarra on
cwradio73
  • 1,162 Answers
Most likely your battery has a cell or two dead oe weak. I think if you replace it you will find it working as it should. The batteries used in this gear is not of high quality. They generally fail in two years r so especially if left not maintained an go down.
Posted on Jan 28, 2015
My izuzu axion 2004 stop working ,don't turn on
step one , head lamps work key off?
yes, good of not battery dead.
2: key on,
cluster lamps all glow, most of them do they>? if not say so.
3: so far so good,, turn key to start. does starter motor run.
gggggggggggggrrrrrrrrrrrrrrrrrrrrrrrrrgggggggggggggggggrrrrrrrrrrr
yes./no
no is a NO CRANK
it wont start until it cracks
also known as a silent starter.
jumper cable start it now
or call AAAtow, they will.
clean battery lugs, of that green stuff. there.
or charge your battery
or find a loaned good charged battery.
or buy a new one, ouch.
can also be you left head lamps on.. Jump start it
or can be phantom drains. (ask)
of can a dead charge system if the problem repeats after the jump.
Mar 07, 2017 | 2004 Isuzu Axiom
Why is battery showing 12.5 volts wont start when turn key on it drops below 11 volts been on charger for hours is the battery bad? possibly some other cause?
Sounds as if battery is no good. Replace with a new battery and have charging system tested to ensure it is working properly
Dec 05, 2015 | Cars & Trucks
2011 dodge nitro. Had red lightning bolt pop up and now car wont start been having problems cranking so.id turn key 3times give gas and usually crank then.it finally gave out wontdo anything.
Electrical problems. Start with battery. Condition? terminal corrosion? Charging system? will it jump start? if it will but dies when jumper cable is removed, charging system has problem.
Auto parts store can check battery, charging system read error codes. you may be able to find problem. If you check google I bet you are not the only one.
Mar 11, 2015 | Dodge Cars & Trucks
2009 jeep commandeer wont start, when I turn the key there is no sound, lights wont turn on and is that wasn't enough the key gets stuck in the ignition. any ideas?
it wont crank, no A/t car starts unless cranked first. (a key point)
fix head lights first. this is a feature in all cars.
that is SIMPLE and HOT all the time
they must work at all times and is the top way to diagnose
electric problems
you have a dead battery,.
only why remains.
i bet it cranks jumper cable started, call AAA or buy some cables.
or swap in a charged battery , or heck charge yours, buy a charger.
check fuses.
check battery lugs for green death?
check battery voltage. at 12.6vdc, if not charge the battery
if the battery continues to disgharge.
that is called phantom drains, or bad battery .
or the alternators is bad.(system)
once started the battery volts must be 13.3.to 15v, if not the charge system is bad ,(fuses, belts slipping and lots more possibles)
Sep 19, 2014 | 2009 Jeep Commander
My Honda Accord wont start even with a jump. The lights come on but wont turn over. No click, no sound, no nothing
IT's those short drives that burn down a battery! The starting of an engine requires mucho electric to get it running. The alternator then charges the battery, but slowly! If you also have the lights and stereo on it is even slower. Get the battery FULLY charged with a commercial battery charger. Then check to see if the alternator is charging up the battery after you start it. If not, replace the alternator. If the battery dies overnight or in a few days...replace the battery.
Jan 24, 2013 | 2005 Honda Accord
Batterie died after trying to jump start it my car was dead i plugged it in to charge i turn the key and the lights work the car wont even click over when turned ignition to start
Make sure you have the car properly in Park with lights off and try. If there's no clicking you either have a very loose terminal on the battery or the battery is no where near charged up enough. Try to jump start with someone wiggling the wires for the jumper cables. Once it starts clicking, leave the wires alone and let the battery accept a charge about 10 minutes while the other car is hooked up and then try again.
Sep 16, 2010 | 2003 Kia Spectra
My hyundai santa fey has just lost all electrics.Drove it fine to shop turned engine off. went to turn it back on nothing -no lights nothing from the battery even the key doesn`t work.tried jump start but...
i would start by checking the connections on the battery and having the battery tested, also why where you taking it to the shop?, if the connection are dirty a jump start wont work, they may look clean but loosen them and twist them on battery terminals to make good connection then tighten them ,and make sure battery is fully charged,
Jun 11, 2010 | 2006 Hyundai Santa Fe
When i turn the key the escape wont start it just makes a clicking noise?
That noise is probably the starter solenoid rattling because the battery charge is low. Start out with a jump or make sure the battery is fully charged up.
May 21, 2010 | 2002 Ford Escape
Van wont start
you may find you have a bad earth somewhere, so i would check the earths. if you have a bad earth at wont matter how long you leave it running the charge will just dissipate, then i would check the alternator again if its not working it wont matter how long you leave your engine running it will not charge the battery.
Jan 21, 2009 | 1998 Ford Escort
Electrical Supplies Logo
113 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
