Question about Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television
Sounds like power supply board. easy fix..remove the back of TV take picture of the insides, and of the power supply board. jot down the part numbers off the board. do not remove till u get the replacement board. be careful back there even if it is unplugged u can get a shock. go to shopjimmy.com or amazon and look for a NEW board using the part # besure it is exact match..
Posted on Jan 28, 2015
SOURCE: Hitachi 55" Plasma HDTV, 1 yr old, suddenly lost picture and sound, but power light still on.
It sounds like a shutdown circuit is being activated. This is normal in cases where the power supply id drawing excessive current. I would suggest that you get this looked at by a qualified professional. This is because this problem may be in the power supply and the voltages can get dangerous in this section of the TV set.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply. Which should cost from 150-250 dollars.
I hope this helps
Shuttle83
Posted on Jul 14, 2008
SOURCE: Can turn on to red light and get blue light, but no picture
The mainboard needs to be replaced
Posted on May 27, 2009
SOURCE: My Hitachi P50H401 50 inch Plama TV stopped
very common issue. if your hand you can repair it yourself.
for more info on this set please check out http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
if will tell you how to trouble shoot this tv. these tv's are known for two caps in the power supply to go bad and they need replaced then you have to test the sdr boards if they are bad you need replacement boards or you can send them off to be repaired. the link for the repair guy is on the page. this guy also sells the repair on ebay but if you contact him directly i beleave the price is lower. just tell him you were send over by home theater shack.
Posted on Feb 22, 2011
SOURCE: the power board has an oscillator IC FAN 7711.one
replace the fan7711 ic when the fet goes it damages this ic
jav
Posted on Oct 03, 2012
SOURCE: Hitachi 50" plasma no picture
how do i fix p50h401 blue light no picture and sound
Posted on Sep 13, 2014
Jul 17, 2017 | Televison & Video
Apr 28, 2014 | LG 32LK330 TV
Mar 19, 2012 | Hitachi 50V710 50" Rear Projection...
May 03, 2011 | Mitsubishi WD-57833 57" HDTV
Mar 27, 2011 | LG 42LC2D 42 in. LCD HDTV
Apr 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Jun 19, 2008 | Sony KP-53V35 53" Rear Projection...
Mar 05, 2008 | Televison & Video
77 people viewed this question
