Question about Kenmore Cooktops
The cooktop stove burners are locked. On my Kenmore elite.How do I unlock them?
Posted by Janice Mecadon on
Lion6
    New Friend:
  • 69 Answers
Press and hold oven light switch on panel
Posted on Jan 29, 2015
5 Related Answers
Anonymous
  • 135 Answers
SOURCE: Kenmore 44083 Cooktop
should be an unlock button.....press and hold the button until it unlocks
Posted on Apr 07, 2008
Anonymous
  • 360 Answers
SOURCE: Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Posted on Feb 11, 2009
Anonymous
SOURCE: gas cooktop - burner won't ignite
if its the burner that hase the intermitent timer on it
i have the same problem & I troubleshooted it.
if u take the cover off thier is a part on it that the rest dont have. its a red thing that rotates & thier are little contacts in it. for some reason thier is something that messed up inside it.
i took both mine apart & switced the guts & one of the little "boards"
is not working properly.
so im shure that is your problem
Posted on Jul 25, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: cooktop is locked out on
Hi and welcome to FixYa. I am Kelly
I could be of much better help with a complete model number I.e. (example 110.XXXXX)
The wait is supposed to be 10 minutes. go back and turn off your breaker by "Physically" pushing it with conviction to the OFF position and wait 10 minutes.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
If it does not go out I will need your model number to go any further.
Thanks for using FixYa and I will be watching for your response.
Kelly
Posted on Feb 18, 2010
Anonymous
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Posted on Jul 16, 2010
How do I unlock the cooktops on Kenmore Elite Electric Range model #C970-440935
Clear the lock mechanism -- as indicated by the DOOR LOC light -- by pressing and holding in the oven door light switch for 20 to 30 seconds. While the switch is depressed, the latch motor will gradually withdraw the lock, allowing you to open your oven door.
Oct 03, 2018 | Kenmore Cooktops
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Jun 24, 2014 | Kenmore White Electric Stove
I can't unlock the stove on my kenmore ceramic cooktop
I was cleaning my range hood and leaning over I somehow set the lock on the cook top. How do I unlock it?
Sep 08, 2013 | Kenmore Elite 44173 30 in. Electric...
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    Kenmore electric cooktop not working on low eat
    If it was the burner element it either would work or not (no in between)
    It has to be the switch
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Apr 13, 2010 | Kenmore Elite 44173 30 in. Electric...
    My Kenmore Range had theoven and stovetop locked symbol on it how do i unlock it
    Either hold down the 'Unlock' button or if the little red pad lock symbol is lid in the main display hold the 'Oven light' button for about 7 seconds...
    Jan 18, 2010 | Kenmore Elite 44173 30 in. Electric...
    How do I unlock the burners?
    there should be a key that you have to press and hold to unlock. find it and press till the light is gone let me know how it goes
    Jun 12, 2009 | Dacor Millennia ETT304 Electric Cooktop
    Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
    Cooktops Logo
    440 people viewed this question
    Top Kenmore Cooktops Experts
    Michael Thomas
    Michael Thomas
    jdthefixer
    k24674
    Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
