Question about Electrolux Epic 6500 Vacuum
VACCUM WONT TURN ON - Electrolux Epic 6500 Vacuum
Posted by HELEN POSTON on
Tristar vacuum
The main motor has a bad carbon brush. It is fixable.
Sep 04, 2014 | Vacuums
Wont turn on
It sounds like the switch had disconnected its a easy fix just remove the screws in the handle around the switch and simply reconnect the wires to the switch. Be sure you unplug you vacuum before you work on it
Jan 17, 2014 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Vaccum wont recline
MAKE AND MODEL PLEASE
May 14, 2013 | Vacuums
VACCUUM GOES ON, MOTOR WORKS, BRUSH WONT TURN WHEN THE VACCUM IS TURNED ON.
check the belt, and remove any objects clogged in the roller system
May 16, 2011 | Dyson Vacuums
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
Wont turn on when pluged in and the plugs that
tighten the center screw in the back that holds the top handle assy on. this always comes loose and causes the vacuum to not recieve power. let me know if this doesnt fix the problem
Jan 08, 2010 | Bissell 5770 Healthy Home Bagless Upright...
My new vaccum wont pick up cat hair
i would return this vacuum while it is still under warranty.
Aug 22, 2009 | Vacuums
Vacuums Logo
Top Electrolux Vacuums Experts
Gerry Harvey
Gerry Harvey
john h
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
