Question about Cell Phones
I have a Denon RCD-N9. I switched it on around 4 weeks ago and on the screen it says 'Update retry. Please wait...'. I have not tried to update anything. I can't select anything or listen to mus
I have tried turning it on and off again. Waiting days for it to update itself. Left it days and then switched it on.
Posted by Sarah Thorpe on
wensch00
    Master:
  • 346 Answers
Denon RCD N7 Owers Thread Go here and ask your question. Good luck.
Posted on Jan 25, 2015
I have a Denon AVR s900 I am trying to update the firmware but it keeps failing. The update repeats and now the unit is not usable. How do I stop this?
Try pressing and holding the "tuner preset ch +" and "tune - " buttons and pressing power. The entire display should light up and blink. This should stop the firmware retry loop.
2answers
My Marantz SR 7007 gives a message "Update Retry Please Wait" and then shuts down and restarts and keeps doing the same.
This sounds like a bad update. Do you have a reset button anywhere? reset to factory defaults? I'd first contact whoever is giving out the updates and let them know the update fails install.
2answers
I have a denon avr-400 receiver. When running a firmware update, i got the error message: Connection fail:03. Now, my receiver is not working. stuck in this endless cycle of failure messages. Help
Unfortunately a failed firmware update will result in an inoperative unit. The solution is to update the firmware directly to the chip. Not a DIY solution. A local Denon repair center will be equipped to do that for a nominal fee. Your unit is a bit older to get much help from the main company.
If you are handy you need a chip burner and the proper setup and then force the firmware onto the chip. Lot of computer guys may have that around to help.
Good luck
My house fuse box is fitted with a master RCD. A feed off a lounge socket goes threw the wall and feeds an external weather proof RCD box which when switched supplies my garden lights. If a garden light...
Appears the main box RCD is just as fast as the secondary RCD and it sensed the same fault that triggered the outside unit and it didn't wait around to see if that outside unit did the job.
My skype cannot update on the iphone 4 it says waiting
This sounds like an issue with the Apple App Store and not Skype. I would wait a bit and retry the update.
May 06, 2012 • iPhone Apps
Failed software download error messages 02 and 10
My version is actually DTR 67500T but I did not realise that you had recorded a different model !! until too late.The shop replaced it with another box
Xbox 360
there was a new update released a few days ago for the xbox 360,it takes around 30-40 min on a 256kbps line..please check your network and download the update..also do not touch the console while its going on..an update may fail if the connection to the internet is faulty..hope it helps!
Cell Phones Logo
Top Cell Phones Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Cell Phone Expert? Answer questions, earn points and help others
