I have an old 3 reel Ballys slot machine & the middle reel wont turn everything else works any suggestions
The middle reel will work a few times & then it stops
Posted by Patti Black on
kazellairien
    New Friend:
Maybe a little WD 40 or some light machine oil
Posted on Jan 25, 2015
Tascam 388 The drive belt broke. After I replaced it for some reason the takeup reel moves backward when I push play. What's up??
This machine uses a servo tension system. I am guessing that when you changed the belt you also upset one of the sensors. You will need to get a service manual and go to the tension setting section to verify or correct what is going on. These units were pretty complicated for regular users.
Apr 06, 2013 | Audio Players & Recorders
When i start sewing the thread tangles and seizes up within 3-4 stitches. I've removed and cleaned the bobbin case a few times.
change the needle
make sure the thread has not come off of the thread take up lever
rethread the machine top & bobbin,, make sure to use every
thread guide
make sure to not over fill the bobbin,, make sure the bobbin is not
warped or damaged
Aug 31, 2012 | Janome DC3050 Computerized Sewing Machine
The bobbin thread wnt catch on my brothers sc6600 sewing machine
try changing the needle
if these suggestions don't work I suggest taking the machine to a
sewing machine shop to be checked
Jul 29, 2012 | Sewing Machines
Brio central station wont turn on
In order to get this to work, you need to bend the battery terminals to make a better connection with the batteries.
1. Open the battery compartment with a screwdriver.
2. Remove any batteries.
3. You need to very slightly bend the positive battery terminals on the top two battery slots. I suggest using a very small flathead screwdriver if you have one. Place the screwdriver between the terminal and the plastic casing and push the terminal toward the center of the battery compartment.
4. Do step 3 for the top and middle battery slot. You don't need to mess with the bottom slot, as it has a different type of terminal connector.
5. Replace the batteries and screw the compartment door shut. Your station should now work!
Jan 10, 2012 | Toys
I have this game down loaded on my windows 7 computer and can not get it to work right! When i click on the game i can get through to where the slot machines are but when i click on a machine to play a...
I dont think you can . I have all the reel deal slots and none of them work with windows 7 directly. There is ittle or no help getting this to work on the EFX support site.
I am just taking the loss and throwing them all out none are worth anything to anybody I cant even give them away.
If there was a Windows 7 help on the support site this could be easier on all who have these.
Probably will no longer purchase the product, because the second there is a change we will be buying them all over again to meet the changes.
Dec 10, 2010 | Phantom EFX Reel Deal Slots Mysteries of...
Hi my Dad has an Akai 1710 reel to reel tape recorder which is in good cosmetic & working order. However when the take-up reel has about 1/3 of tape on it the motor tends to slow down somewhat. What...
Most of the old tape units had rubber "pucks" and belts thaat drive the reels..
The pucks tend to dry out and deteriorate. You MIGHT be able to restore them a bit with the spray used to restore typewriter plattens.
Nov 15, 2009 | Audio Players & Recorders
N64 wont turn on... i miss it
Had the same problems.. the n64 just turned off after playing dr. mario for a few minutes... anyways, heres what worked for me
1. make sure your wall outlet works *sounds dumb, but better safe then sorry, plug in a light or something to make sure it works*
2. unplug EVERYTHING, controllers, vid cord, power etc
3. let everything be disconnected for about a minute or so, the AC adapter sometimes overheats and turns it self off which might be the problem.
4. ONLY plug in the AC adapter to the n64, make sure its firmly plugged in. turn it on.. it should light up now, if so, plug everything back in. enjoy :)
Aug 29, 2008 | Nintendo 64 Console
Repairing or replacing old tape decks
Hi m522posner
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
Vintage Electronics
P.O. Box 941
1241 Conestoga Creek Rd
Florissant, Co 80816
Email: [email protected]
You could have a go at freshening up the belts yourself:)
regards
robotek
Jul 10, 2008 | Sony Audio Players & Recorders
Tascam 38
Usually the tension of the take-up reel keeps the shut-off arm taught and everything works. If the shut off arm falls down, the recorder stops. Is that what's happening?
Inadaquate (or NO) take-up tension can cause this; so can WARPED take up reels. Another possibility: if you play a lot of old tapes, the groove in the shut-off arm collects dirt and oxide, so the tape - as it goes through it - jams, and the take-up reel can not overcome the tension. The arm "falls down" and shuts off the machine. Also SOME tapes (which were "cut down" from 2"
tapes) are poorly ****, and will jam some machines.
This is what I do for a living, so if these suggestions don't work, give me more information, and I'll solve your problem.
Jan 01, 2008 | Audio Players & Recorders
Machine won't work. kenmore 90 series
Might be a broken motor or a blown fuse. I would suggest having your machine looked at by a specialist. If it's old, you might consider replacing it.
Mar 21, 2006 | Kenmore 15864/15862 Top Load Washer
107 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
