Acer Aspire 5610-4648 Notebook Logo
Question about Acer Aspire 5610-4648 Notebook
What is the difference between the Acer Aspire Laptop models 5610 and 5610Z? I had a 5610 with a broken case and put the insides in a 5610Z case after removing the defective 5610Z components. I fail t
I rebuilt my trusty old Acer laptop.
Posted by Richard Schneider on
  • Richard Schneider
    Richard Schneider Jan 25, 2015
    I fail to see any physical differences. They share the same motherboards and other components.
5 Related Answers
Anonymous
  • 66 Answers
SOURCE: POWER BUTTON STUCK
If the power button is under the screen you can check easily. You will be able to see little slots. They make tools that will help you open them. Once you open it,it should be there
Posted on Mar 12, 2009
Anonymous
  • 38 Answers
SOURCE: how to dissemble acer aspire laptop, motherboard failure
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/ this path will take you to step by step disasembly
Posted on Mar 24, 2009
Anonymous
  • 79 Answers
SOURCE: power jack needs replacing aspire 5050 model zr3 laptop
Hi I will help you. Under the screen and above the keyboard is the power button panel. take a small flat tip screwdriver and carefully use it to pry up one side of the power button panel. you may even need to pry up on the part of the panel that covers the hinges. Once it start to release, grab the panel and kind of wigggle it back and forth, while lifting it. it should start to release all the way. Once removed, the top of the keyboard is exposed, remove the keyboard being careful of the short ribbon cable connector underneath the keyboard.
once keyboard and panel are removed, you'll need to remove the screen via the screws on the hinges. make sure to disconnect ANY of the cables to the screen (usually video cable and wireless cables. And disconnect one small ribbon cable that looks like it comes from the touchpad mouse.
Now check where you removed the keyboard, you should see several sscrews that you need to remove.
At this point, if all the screws are removed, you should be able to disassemble thelower chassis of the laptop. Be very careful not to break anything. You will need to also remove several screws in order to get the motherboard out of the laptop.
I will give you the web link of where I buy ALL my power jacks for my repair shop. A guy named Gary Shaftsall runs DC PowerJacks, and is a great guy to do business with, not to mention he sells the jacks @ wholesale price.
His website address is:
http://dcpowerjacks.net/catalog/index.php
I urge you to be soooo careful in putting it all back to gether, I would hate to see you put a long screw into a shallow hole. this could result in a MAJOR short of the motherboard. Just keep track where all screws go and how the parts go together.
Hope this helps, please rate my solution.
Posted on May 12, 2009
Anonymous
  • 192 Answers
SOURCE: Hi, I have an Acer Aspire 5535 with password in the bios
Unfortunately, if he put a sysetm BIOS password and doesn't remember it, you need to contact Acer's website.
You can have a electronics technician jumper all electrical current to wipe out the BIOS password, but contact acer first to make sure that there is not another method.
Posted on Aug 09, 2009
Anonymous
  • 268 Answers
SOURCE: Need Instructions on How to Replace ACER Aspire 6920 Laptop LCD
To do this you are going to need the service manual for your model laptop. In the service manual it will tell you how to completely disassemble the laptop. It will show you step by step and with photos.
Now I searched for a service manual for this model. I found one that is free, but will require you to participate in some free offers. I also found one that will cost 7.95 euro's (something like $12.00), but you will be able to download it immediately. You can try searching some search engines to find one for yourself, just try searching "Acer Aspire 6920 Service Manual", you may have better luck. Either way I put the links below if you were interested in what I mentioned. Good luck with your project.
Service Manual For 7.95 euro
Free Service Manual after completing offers
Posted on Oct 20, 2009
2answers
How to open the aspire5630 laptop bottom part. some of the screw holders are broken. can the body be replaced or repaired. ? and my bluetooth is not working as well how to fix it.
This may not be your exact model but here's a video: http://www.youtube.com/watch?v=pPdw-pkS88k Is the blutooth listed in Device Manager? Have you done ALL your Windows and Acer updates? You can find drivers and user manual, support here: http://www.acer.com/worldwide/support/
Acer Aspire 6930 charge port problems
The DC jack in the laptop may need to be replaced, go to www.ebay.com Type: make and model of laptop, refine search to DC jack or scroll through the list. The laptop must be completely dismantled down to the motherboard and removed from bottom base, soldering equipment a must with the skills to use it, suggest a computer repair shop.
2answers
ACER ASPIRE laptop PgUbp key came off.
Unless I'm missing something, just put the key back where it belongs. Push down hard, and it'll snap back into its place. If this doesn't work, check the underside of the key. If you see broken plastic, you'll probably have to find a new key. Acer laptops seem to have a problem with keys coming out and breaking (just look at the number of times this question has been asked!)
hope this helps
Cannot detect the acer orbicam built in webcam on my laptop acer aspire 5570
1. Check the device manager to see if there is a conflict.
2. Reinstall the driver
3. Special Note: Acer actually put 3 different brands of cameras in that model. So, if the laptop or manual doesn't tell you which one was installed in your particular machine, you may need to install each of the three drivers one at a time to see which one registers and gets the camera working.
4. Just in case you were interested as I would be... Acer does not consider this laptop to be Windows 7 ready.
Good luck and Merry Christmas.
2answers
ACER ASPIRE 3680 LOOKS LIKE INK IS BLEEDING INK INSIDE OF IT..
It indeed is a fairly easy repair in case of your Acer. However you will need a replacement screen which would cost a lot if you order it new. You might be better off searching ebay for a broken "donor" laptop (make sure it's exactly the same model, as even similar models with same screen dimensions might have different connectors or inverters - I learned the hard way ;)
Good luck,
Raf
1helpful
Left touchpad button stopped working, Aspire 5500
Touchpad keys can wear out, especially in this acer model. You can contact a laptop repair near you or Acer directly for the replacement part. It's not difficult to replace, but you will have to remove the keyboard and the top half of the case to do so. It's usually only held in place by 1 or 2 screws to the under side of the plastic case.
1helpful
My laptop won't turn on
a copoment inside the laptop might be broken. go to where you bought it from and ask them for a new one or to repair it. this is only if it comes with a guarantee though. or just ditch it and buy a new one. never try to open or repair it yourself though the electral shock could kill you even when it is off.
Power button from my laptop acer aspire 3680 is broken
their are many people who sell laptop parts on eBay, I suggest looking there.
Steve Sweetleaf
Steve Sweetleaf
shadow
