I turn my TV on and get no response no lights no nothing comes on.
I have the back of the TV off I have checked to make sure I do have power going to the TV I have a good fuse in the power cord and I do not see any signs of burn marks or blown capacitors
Posted by Tj Hudson on
Andrew Lohbihler
    Master:
  • 505 Answers
Check that the power cable plug is firm seated in the power board. This is a simple thing but sometimes it comes loose or stays loose after servicing the power board. Also, check that there is power to the secondary lines that will tell you that the power board is operating. Otherwise you likely have a defective power board.
Posted on Jan 25, 2015
5 Related Answers
olayoju victor
  • 191 Answers
SOURCE: TV won't turn on, please help......
change your power suply
Posted on Nov 02, 2008
Anonymous
SOURCE: 42hdt79 Hitachi TV will not power up. Cord is good TV is dead ??
Try the button on the front bottom, under the power button on the front.
Posted on Apr 07, 2009
Anonymous
SOURCE: Element FLX 3211B has no power after 14 months of
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
Posted on Apr 27, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: tv did not turn on
Look at the power supply to see if anyhting burnt, fuse, bad capacitors. I doubt that the power cord is bad, the same size fuse should be used as the original one.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 04, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I watching TV, (FLX3211B) turned it off and then
You may have to replace the power supply module if you do not want to troubleshoot it down to component level. The fuse blown may be due to the power surge or shorted out components.
The standalone power supply may be hard to find. You can try here:
http://www.shopjimmy.com/catalogsearch/result/?q=FLX-3211B
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Nov 19, 2010
Testimonial: "Th\anks that giveds me a place start"
We came home from a weekend vacation and the TV won't turn on at all. there are no lights, no response from the remote, nothing. It worked fine on Friday and now Sunday, it is shot. I thought possibly...
Hi, Check that the plug has power. Use a light to do this. Also check the TV cord maybe bad.
Check breaker pannel. Make absolute sure that you have power getting to the TV. If all is good you need a repairman. Good luck
Jun 20, 2011 | Westinghouse 32" Flat Panel LCD HDTV
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Mitsubishi
i just sent the response to your email address
Sep 16, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
