Question about Panasonic Viera TH-42PX80U Plasma TV
After a few days the tc50x5 works fine
Putting cable in freezer for two days
Posted by Hersel Johnson on
Andrew Lohbihler
    Master:
  • 505 Answers
You could have a defective cable or its badly connected to the TV. Check that it is firmly seated in the power slot when powering up the TV. Check that it snaps into the slot and then power up.
Posted on Jan 25, 2015
Refrig and freezer working on and off for 2 weeks
have you gone here with the model # and cked out what the site says...
https://www.repairclinic.com/?clearLs=true
without a model # is hard to help.
Jan 01, 2018 | Frigidaire PLHS67EGSB Stainless Steel Side...
Freezer makes intermittent fan noise
one time i ran into this problem and found out the lady was putting hot things in the freezer creating alot of moisture. check your door seal also make sure its sealing if it had gaps you can heat it up with a hairdryer to streach it out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 28, 2010 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Freezer Temp keeps getting too high
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 21, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer not working well ....
CONTROL SWITCH PROBLEM
May 20, 2009 | Freezers
Both freezer and refrigerator temp variations
in most refridgerator cabins is a air dam at top right of side by side and it could be sticking open and working other times or it could get stuck in defrost cycle due to defrost timer not working properly.defrost timer would be first thing to look to.
Apr 20, 2009 | Refrigerators
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Panasonic Viera TH-42PX80U Plasma TV Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
