Question about Amana Microwave Ovens
Troubleshooting- microwave turntable and fan run constantly when door closed, door switches test good, timer can be set and oven runs otherwise; need amana microwave ACM1580AS wiring diagram
Tested door switches top/ bottom have continuity with door closed. middle switch closed when door open. Have to open door to shut off turntable. have to unplug cord or light stays on.. other wise microwave works as it normally did.
Posted by darryl furse on
Dave
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
I'd look for a defective relay or shorted triac on the control panel circuit board. Either could cause this problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on Jun 25, 2016
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Dec 26, 2012 | Magic Chef Microwave Ovens
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
My ge microwave just runs. It will not stop unless I unplug it.
First you should determine whether it's cooking when it should not be, in this case anytime it is plugged in and the door is closed or open.
Do that by putting a cup of water in a microwave-safe container into the unplugged microwave, shutting the door, then plugging it for about a minute.
Then unplug the oven and check to see if the water is warmer.
If so, you have a shorted secondary relay on your microwave''s control circuit board, and we regularly repair such control units for customers nationwide by mail for $39.95 with a one-year guarantee.
Do that test again by putting the water in, leaving the door open, and plugging the oven in for about 30 seconds or so. If you get any arcing or buzzing or flashing, unplug it.
If it is not cooking, then you need to test further.
If it just seems to be "running" with the door shut, but it is not cooking (as shown in the above tests) then note whether the oven lamp, internal cooling fan and turntable are running when the door is shut, but when you open the door, the turntable and colling fan go off.
This should mean you have a shorted main relay on the board. We can fix that, too.
Differing symptoms would indicate a bad door switch or door switch mount.
Our info file on door switches is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 30, 2010 | GE HVM1750SMSS Microwave Oven
Our Microwave keeps running unless we give it a whack!
Hi firstly to see if it is producing energy, buy some 5mm light emitting diodes from an electronics store. cut off the leads close to the plastic body.
place in microwave and put on cook for max 10 secs, if the led's light up you have microwave energy, shut off the oven as soon as they glow otherwise you end up with a mess.
If you have energy then your problem is most probably the door interlock micro switches which after time do not operate properly. let me know the results and we can go further.
Feb 23, 2009 | Danby DMW1153 Microwave Oven
Sharp Carousel Microwave Model R520-LK timer will run but carousel doesn't turn and food doesn't heat.
I also have the Sharp Carosoul oven, symptoms - fan runs, controls are fine but the turntable stopped turning and it did not heat. It was not the switches, fuse, but in fact a sagging door that misaligned with the door switches. The true cause was a warn top hinge. As a temporary fix, I adjusted the bottom hinge (3 screws underneath), straightened the door, and now it works again.
Dec 16, 2008 | Sharp Microwave Ovens
Door shut off malfunction
I have the same problem starting yesterday April 19. Have you gotten any answers.
Mar 12, 2008 | Panasonic NN-T993SF Microwave Oven
Fan runs when door is closed, but no heat.
It's probably a bad door switch or switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Microwave Ovens Logo
589 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Michael Thomas
Michael Thomas
Mike
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
