Will this work on my lcx27c fishfinder
SOURCE: gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
SOURCE: i have a lowrance 520c
To restore default settings: 1. Press MENU' MENU, use ? ? to select NMEA 2000 and press ENT. The NMEA 2000 menu will appear with five options: Bus Setup, Fuel Management, NMEA 2000 Alarms, Waypoint Sharing and Backlight Synchronization. 2. Highlight BUS SETUP and press ENT, which will open the Bus Configuration menu. A list of network devices will be at the top of the page. 3. Select the desired temp sensor and press ENT. The Device Configuration menu will appear. 4. Highlight ADVANCED OPTIONS and press ENT. 5. Select RESTORE DEFAULTS and press ENT. The following message will appear: Are you sure you wish to change this device's configuration? 6. Highlight YES and press ENT. Press EXIT repeatedly to get back to the
main display.
You can also get the manual on the lin kbelow page 216 on will tell you how to restore
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS525CDF-520C_0151-461_120706.pdf
Good Luck
SOURCE: My Lowrance LMS-332C GPS was
Hello 2# Make sure the power cable is wired properly. The red wire connects 4# Measure the battery voltage at the unit's power connector. It should be at least 10 volts. If it isn't, the wiring to the unit is defective, the battery terminals or wiring on the terminals are corroded, or the battery
If the GPS works and sonar section does not work at all, check the followings.
1# Check the power cable's connection at the unit. Also check the wiring
to the positive battery terminal, black to negative or ground
3# Check the fuse.
needs charging.
Check whether there have any wiring break, loose. During servicing the boat, there is chance to get the wiring of sonar to sonar sensor at the botom of the boat may have damaged. Check these. OK.
