Computers & Internet Logo
T
Terry Higgins Posted on Jan 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get rid of a flashing message "Display Mode out of range"
Beowolf Jones
Level 2:
Habit-Forming:
New Friend:
  • Expert 79 Answers
  • Posted on Feb 03, 2015
Beowolf Jones
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
79
Questions
0
Helped
17844
Points
223
Here is an article from Microsoft on this problem. Good Luck !
How do I get rid of a flashing message Cause This behavior can occur if the signal from the video adapter exceeds the scan range of the new monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor. Back to the top ' Give Feedback 20x20_grey_minus.pngResolution To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
  1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
  2. Right-click the desktop, click Properties, and then click Settings.
  3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
  4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
  3. Click Advanced, click Adapter, and then click Change.
  4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
  5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
  6. Click Standard Display Adapter (VGA), and then click Next.
  7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
  8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
  9. Click 256 colors, click Apply, and then restart the computer.
  10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
  11. Click Device Manager, click View devices by type, and then click Display adapters.
  12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
  13. Install all updated monitor drivers.
How do I get rid of flashing Display mode out of range message
Terry,
That monitor only has VGA in port. So it sounds like the computer VGA out port is not sending a correct 1024 x 768 at 75 Hz signal to the monitor. The problem could be a defective video card.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Get message F9 on the display, I went to clean the oven in the self cleaning mode, heard the door latch trying to close, then it started beeping and flashing the F9 on the display. I turned off power for...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
F2E1 message on range
I have a repairman coming to check it out.
2helpful
3answers
Www.ge.net How to get rid of flashing lock door on JGBP35
There is a button on the left upper corner by the door when you open oven. Hold the button down and press the clear button on the panel till the display clears itself. Just like that you have a functional oven.
Flatscreen goes blank and displays the message
Out of range indicates that the refresh rate or resolution is set too high for the monitor to display. I would suggest re booting into safe mode by pressing F8 during boot, before windows begins to load. Select safe mode with networking if you can, and once in safe mode, uninstall the ati display driver from the control panel. Then go to ATI's site and download the latest driver for your card. Save that file to your desktop. Reboot normally, as Windows should load default vga drivers for your card. Once in Windows, install the latest driver you just downloaded. That should reset the resoultion to one that your monitor can display. Good luck:)
Over range auto detectable flashes across screen
Restart the computer in safe mode by tapping the "F8" key as it comes on. Then open display properties and set the display settings to a lower setting and restart the computer.
You
2answers
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Flash forced off
The Rectangles with a 'M' in it is the Multi-Burst mode. U must select 'Normal' Mode. Try this:
In the Autoshoot mode --> press menu --> Change back to 'Normal'.
You will now get rid of the rectangles with the 'M', and you can change your flash settings.
Grand Canyon Tech
Grand Canyon Tech
