Replaced lamp
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
SOURCE: Have sound no picture?
if the fan is cutting off and ON there is a problem with your power supply unit.
and this may also affect your other systems on the unit
SOURCE: sound no picture?
I have no solution for this problem and I'm not sure I can fix it without taking it to a repair shop. The replies I got yesterday did not help.
SOURCE: i have a toshiba 52hm84 green light blinks 10 but
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
