Question about Alcatel Cell Phones
Change apn settings on alcatel one touch model A995L
Posted by Morgan Nichole on
Richard Macbeth
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
The first thing you'll need to do is find the right APN settings for the network you want to use. You'll be able to find these at the support pages at the carrier website. The settings will look like this example for Straight Talk:
  • NAME: straight talk
  • APN: tfdata
  • PORT: 80
  • MMSC: http://mms-tf.net
  • MMS PROXY: mms3.tracfone.com
  • MMS PORT: 80
Once you have this information at hand, grab your phone.
Open the settings, and look for Wireless and Network settings. Once there, look for an option to see "more". You'll be presented with a list of options to select, and we're looking for something labeled "mobile networks".
Once you've found your mobile network settings, the rest will be the same on all devices. You're looking for the "Access Point Names" section. Tap to open it.
You should see a list with at least one APN on it. If things aren't working with the current APN, you need to add another. Don't modify or delete the one you see, instead make a new one and we can choose it when we're done. At the top of the page, or possible in a menu if your phone has a menu button, press the plus sign to bring up the "Edit access point" screen.
This is where you will enter the settings you got from your carrier's website. Two very important things here:
  1. Not every setting in the "Edit access point" screen will need filled in. Only fill in the items your carrier provides, and leave the rest as-is.
  2. Be sure to type in everything exactly as provided by your carrier. For example, default,supl,hipri is different than default, supl, hipri because of the spaces between items. Your carrier's system is set up to read an expected set of values, and any changes - no matter how minor - can and will break things.
Once you have the settings provided by your carrier entered, you need to save the APN. You do that by pressing the three dots in the upper right (or the menu key if your phone has one) and selecting the "Save" option.
Once your APN information is saved, go back one screen to the list we saw earlier. On this screen, tap the new APN settings you just entered to make them active.
Most times, you'll need to physically reboot your phone to use a new APN setting, but once properly entered, chosen and working, your phone will choose the correct one automatically whenever it's rebooted or Airplane mode is toggled.
Posted on Jan 23, 2015
I need an unlock code for an Alcatel one touch model ALCATEL A392CC A392CC-2ALZCA1 014594004620080 Would be a great help I'm trying to set it up for my elderly neighbor she can call me w/e need arise
Get the unlock code for an Alcatel one touch model ALCATEL A392CC A392CC-2ALZCA1 and any other Alcatel model
land the below unlockninja page and fill the required information like IMEI no, network, country, e-mail ID etc and to generate the unlock code and get the code on your mail in very short time
Unlock alcatel Phone How to Unlock alcatel Phone
https://www.unlockninja.com/unlock-alcatel+phone
Aug 21, 2018 | Alcatel Cell Phones
Model 5098s Alcatel ,I am on 2g network,I have tried to change to 4g but it just would'nt change ,checked apn, data sim ,network ,rest network still would'nt work,how can I activate 4g.
you have not mentioned a country but some places have closed down the 2 g network and the 2 g phone is not manufactured to work on 4g
Mar 25, 2017 | Alcatel Cell Phones
I have an Alcatel one touch powered by android with straight talk. I can send n receive text messages but now for some reason I can't send or receive pics while texting .how do I fix this? Thank u
Call straight talk and ask them for their apn settings, theb you need to put the right apn info to your Android device by going to settings, networks,mobile networks then access point names, and enter the info you get from your provider
Jan 08, 2016 | Alcatel Cell Phones
How do I update my alcatel A995L? It keeps telling me authentication failed, please contact your service provider.
you personally can not update your phone that is why they tell you to contact your service provider . has to be an authorized agent .
Oct 06, 2015 | Alcatel Cell Phones
How do you change the apn settings on the alcatel one touch 888A?
Settings>Wireless & network settings>Mobile Networks>Access Point Names> New APN
Jul 15, 2015 | Alcatel One Touch 888A
Cant recieve or send out mms
Here are the APN settings for your phone and T-Mobile.
These need to be correct for mms to work.
APN & data settings
To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Wireless & networks.
  4. Open the Access Point Names or APNs. menu (in steps above)
  5. If there is a T-Mobile APN, touch it. If not, press the Menu key, and touch New APN.
  6. Verify and update the following settings for the Data APN:
    • Name: T-Mobile
    • APN: epc.tmobile.com or fast.t-mobile.com (for LTE devices)
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not Set> OR Internet+MMS (depending on software version)
  7. Press the Menu key.
  8. Touch Save.
  9. In the list of APNs, delete all others that may appear. If there is a FOTA APN, you may leave that one. To do this:
    1. Touch the APN you want to delete.
    2. Press the Menu key.
    3. Touch Delete APN.
  10. Verify that there is a circle next to the one remaining APN to show it is activated.
  11. Perform a soft reset.
  12. Test your data connection, by accessing a web page or sending a picture message (MMS) to yourself.
Sep 15, 2014 | ZTE Concord Blue Smartphone - T-Mobile 832...
Setting apn
Open the main menu and touch "Tools & Settings". Touch "More" and select "Connection". Select "Access Points" and touch "Add profile". Type the settings for the connection. Enter a name for the connection in the "Connection Name" field. Verify the Bearer field is set to "GPRS." Set the "Authentication" setting to the type specified by your carrier. Type the username and password in the specified fields. Enter the access point name in the APN field. Touch "Save" to confirm.
Mar 12, 2014 | LG Encore Gt550 Unlocked At&t Touch Screen...
Cell Phones Logo
994 people viewed this question
Top Alcatel Cell Phones Experts
Dakshinamurthy...
Ron Rak
Ron Rak
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
