PACKARD BELL; 12. 05. 2012 ; RO: EMEA. non functiong keyboard
Hello
Does the whole keyboard not work or only some keys?
Try the following shut down the computer , disconnect the power cable and remove the battery from underneath then press power button for about 20 seconds then reconnect the battery and the mains power and switch on the laptop again.
Did you spill any liquid on the keyboard?
SOURCE: packard bell easynote m5262
This is hard you have to take the laptop apart to get to the ram. but you have to remove the screen to get to the case screws.
SOURCE: need to make laptop notebook packard bell dvd region free locked on o1
You can only change the region code up to 4 times then it locks on the last change.
There are some firmware upgrades that can change the drive to region free, if you can screw it up or put in the wrong frmware upgrade then the DVD drive will be a piece on junk.
I suggest you install a region free software that will allow you to play any region DVDs.
Go to www.dvdidle.com to get their Region-Free software, it is not very expensive.
SOURCE: packard bell e1245 crash
try press f5 when system is starting up then go safe mode, then try to restore your system to earlier setting with system restore. system restore is located on start/accesories/systemtools/system restore.
SOURCE: The touchpad stopped working on my Packard Bell EasyNote TN65
could be malware infection but before, open and check that touchpad to motherboard interface flex is ok and well plugged in the socket. also uninstall all touchpad drivers, run a malware removal tool then, scan for new hardware..
Regards
