Computers & Internet Logo
D
DALE CRAMPTON Posted on Jan 23, 2015
ASUS 1005HA ASUS 10005HA MEMORY
1helpful
Asus Eee 1005HA hangs on boot
This works for my Asus Eee PC
1. Shut down and remove the battery.
2. Press the power button 10 times, next 1 minute pressing down.
3. Remove the memory and at the motherboard you'll see a clrrst (clear reset cmos..)
4. Short these 2 tiny pads by placing a tiny screw driver for 5 seconds, plug the power adapter and turn-on the switch, next wait at least for 3 seconds. Remove the power adapter.
5. Place back the battery and turn-on. You'll see the same screen (Logo of Asus) then patiently wait for at least 10 minutes or more. That's it.Good luck.
My asus 1005hab is frozen on the ASUS screen. Tab takes me to Megatrends but no further
Remove any memory cards you may have fitted and try again. If still the same then I suspect a hard drive (Memory chips) may have failed. Again remove the cover and disconnect the ribbon cable as see if gets past where you are now.
No sound
you can download the ASUS Eee PC 1005HA-PU1X-BK Netbook driver from the link provided below
2answers
Where can I order an adaptor/charger for my Asus 1005ha?
Usually on the manufacturer's support site, so am going to suggest you go to the ASUS support site and try!
The key 'c' is not working either upper or lower case. ASUS 1005HA netbook.
1. Your contacts in the keyboard are either worn or the trace to the controller board for the letter "c" is not responding.
2. You will have to replace the keypad or send it to Asus for repair.
Contact Asus and ask for technical support.
1helpful
Bios version for asus eee pc 10005ha touchpad screen freezes
Its not the Bos,just dont corrupt the boot procedure with unnecessary key presses.
Or reinstall factory settings properly--it has very little to do with the bios
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
