Question about Dell Dimension E520 PC Desktop
I'm trying to upgrade from Vista to Windows 7 and I need to boot up from the disc. My BIOS states the CD Rpm Drive is not present. Can someone help?
Start the computer and when the very first screen comes up which says usually 'f2 or delete to bios' or something like that, press it.
In BIOS there is a section which says the boot sequence. Go to this and change it to the CD/DVD drive to load first. If it doesn't, it will try and load from the drive first and you will not be able to boot from the CD.
Posted on Jan 23, 2015
SOURCE: dell e510 cd dvd rw not working
Try going into your Device manager start right click on my computer click on properties then click hardware tab. Under this tab click device Manager. Under disc drives find the drive that you are having problems with and right click on it. Then try to update drivers. If this dose not work do the same thing but this time uninstall the drive. After it uninstalls go to your controll pannel and click on add hardware. It should find and reinstall the cd rom and it's associated files and hopefully work once again.
Posted on Apr 29, 2008
SOURCE: BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
Posted on Nov 17, 2008
SOURCE: Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Posted on Mar 24, 2009
SOURCE: Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
Posted on May 28, 2009
SOURCE: selected boot device is not available
I had the same issue with my dell dimension 2400. The issue I was having resulted in the connection to the drive was loose. Try taking off the side of the case, find the drives in question and reseating the plugins. My pc was quite a bit older though and i don't know if this will be your solution, but its worth a shot. You can even try installing a different cable and swapping to another power supply plug.
Posted on Aug 10, 2009
Oct 20, 2013 | Philips Dh-16a3s & Lite-on Dvd/cd...
Apr 17, 2017 | Compaq Creative Sound Blaster PCI 128...
Jan 13, 2013 | HP Pavilion Computers & Internet
Aug 19, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Mar 26, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Aug 23, 2010 | HP Pavilion dv6000z Notebook
Jun 04, 2009 | Gateway Computers & Internet
Mar 21, 2009 | Dell Inspiron B130 Notebook
Mar 07, 2009 | Computers & Internet
Jan 31, 2009 | Lite On SOHC-5236V CD-RW/DVD-ROM Combo...
54 people viewed this question
