Question about HP Deskjet 3510 e-All-in-One Printer
Print job stuck not deleting even shows deleting how correct
Tried deleting in What printing disconnecte printer and turned off power still just shows deleting in whats printing
Posted by Thomas Healy on
Joel Rodriguez
    Sergeant:
  • HP Expert
  • 465 Answers
Start with this link
http://windows.microsoft.com/en-us/windows/printer-problems-in-windows-help#fix-printer-problems=windows-8&v1h=win8tab1&v2h=win7tab1&v3h=winvistatab1&v4h=winxptab1
Posted on Jan 23, 2015
Robin Vaughan
    New Friend:
  • 29 Answers
I would try re-installing the printer software. If that doesn't work, a simple system restore to a couple of days ago will sort it out.
5 Related Answers
Anonymous
  • 1605 Answers
SOURCE: HP Laserjet 1018 won't delete a printing job
to delete the print job.
shut off the printer, disconnect the printer cable to the computer.
go to strat>>printer and faxes.
open the pirnter queue. stop the print job then delete. you may have to restrat the computer.
once the job is deleted, connect the printer cable back to the computer and turn on the printer.
Posted on Jan 09, 2009
websnail
Martin Smallridge
  • 419 Answers
SOURCE: printer will not cancel print job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Posted on Jan 25, 2009
Anonymous
  • 5 Answers
SOURCE: Uncleared print job HP J5780
Try stopping the print spooler service and canelling all the documents.
The Windows Print Spooler is a Windows XP "Service". You can start/stop it via the following steps:
  1. Click on the Start button
  2. click on Run
  3. enter "services.msc" without the quotes and press Enter
  4. Scroll down to Print Spooler
  5. Single-Click on Print Spooler
  6. The details will open in the middle of the window.
    • It probably shows Start -- if so, Start it.
    • If it shows Stop and Restart, I suggest Stop it, then Start it.
Posted on Aug 15, 2009
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: Cannot delete a print job
Microsoft has the help you need for this issue and I wont try to give you long and possibly misleading information on here.
It is a common problem but the answer is here
http://support.microsoft.com/kb/946737
You need to refer to method "D" about half way down the page
Once you clear the print job check you dont have any extra printers installed as quite often happens in these situations. If you have then delete your extra printer installations.
Posted on Oct 03, 2009
PRINTER WILL NOT PRINT THERE IS A JOB THAT WON'T CLEAR. I TRIED DELETING THE JOB AND ALL IT SHOWS IS THE JOB DELETING AND THATS WHERE IT'S STUCK
To clear the print queue from stuck print jobs, try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Oct 02, 2011 | Lexmark X2500 All-In-One Printer
My z35 printer wont print. It is on and wired correctly but when I push print nothing happens. i have enough ink
Try to check if you have Print jobs stucked in the queue and if you do have just delete them first and try to print. Also, you can try to disconnect the printer from the power by disconnecting the black box at the back of the printer where the power is attached. Wait for 20 seconds and connect back the power brick. If the printer doesn't turn on automatically you can press the power button. Then you can try to print again if the printer is ready. If still the same I would suggest contacting Lexmark Technical Support. Thanks.
Aug 12, 2010 | Lexmark Color Z35 InkJet
Printing Problem
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Jan 28, 2010 | Lexmark X73 All-In-One InkJet Printer
We have a spooling problem. The sharp mx-2300n just says "ripping" and 20% complete but won't move from there and print anything. Can cancel print job from Mac but won't stop anything at the printer end....
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
Sep 07, 2009 | Sharp MX-2300N Color Copier
Uncleared print job HP J5780 I'm pulling my hair out trying to print to my HPJ5780. With a failed manual duplex job, I tried to delete the print job from the queue. It came up fine as deleting - however...
  2. click on Run
Jul 16, 2009 | HP Officejet J5780 All-In-One InkJet...
Jan 09, 2009 | HP LaserJet 1018 Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
1 document stuck in que
Hello u6rysl,
Turn the printer off.
Reboot your machine.
Go back into the print queue and remove the print job.
- Vincent
Hp psc 1410 cannot delete remote redirected print job
There is a option in printer box "Purge Print document" you try that option, After Purge then delete the document, which is still present in your box. At a time turn off the printer. All the pending printing commands will delete.
Mar 18, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Deskjet 3510 e-All-in-One Printer Logo
efs_perpends
efs_perpends
k24674
