Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Refrigerator and freezer running warm
I have a model GE PSC25MSTASS. I've had problems with the refrigerator and freezer cooling intermittently. The motherboard was replaced along with a compressor control recently About three weeks later, it's doing the same thing again. Refrigerator at 48 degrees, freezer at 10 degrees. It's obviously not defrosting again and the compressor/fan run constantly. Last time this happened the service tech pulled the back off the freezer and the coils were all frozen up. He ran some tests and decided the motherboard and compressor controlled needed replacing.
Posted by clw100ret on
Anonymous
    Problem Solver:
  • 14 Answers
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Posted on Jul 07, 2009
I have a ge frige that the freezer works but frige is warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
I have a ge tfx24fg the fridge part is to warm
heatman101
Nov 07, 2010 | GE PSC23SGRSS Side by Side Refrigerator
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 02, 2010 | GE GSH25JFT
Have a ge refrigerator model tfx22prx, the freezer is running about 5 above zero, but my problem is the refrigerator to warm running aprox. 48 above zero
heatman101
Sep 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Psc25mstass the evaporator is frosted up in the fresh food section. What keeps the evap. coils defrosted and or what makes them frost up? The fresh food section is not cooling>
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 25, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ge Profile fridge Model #PSC25MSTASS Wacky temps in Freezer for several weeks, so much so that ice will not stay frozen, so we just shut the ice maker off. Most of the other foods would stay frozen,...
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Sep 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
My refrigerator/freezer intermittently gets warm
GE had a problem with their units I dont see which model you have here but if you pull the unit out and look on the back wall lower right side and see a cover plate with about 10 screws in it ther is a main ctrl board in the and it controls just about everything in your unit There is a relay on the board that controls the compresser as well it maybe sticking at times. The crappy part is you can not just replace the relay you have to replace the whole board.. if this is the case post the model # and i will get you the part# and cost on a replacwement it is something you can do yourself
Jan 24, 2008 | Refrigerators
Refrigerators Logo
1,110 people viewed this question
Top Refrigerators Experts
Ron Rak
Ron Rak
gbob59
