Make sure pump is primed and make sure circulation pump is running
For a test only, remove filters and see if you feel anything against the fitting?
If nothing either 'Air Lock', keeping it from priming the pump.
Or, bad pump!
Secondly, are you still dealing with a problem?
Use the comment link on this thread, and let the forum know if you are, if repaired, what did you do?
Intex link...
Support Intex
Hi Mike, what do you mean by air lock and how do i fix it... im noticing that we only have suction from the filter closest to the pump but the second one at the far end of the spa has no suction and that filter stays bright and clean while the first one gets dirty quickly... its been this way since we bought it a month ago... we cant seem to keep our water clear and feel like this is definitely contributing to that problem...
I know it's a pain, but don't let Intex get away with this, The 86" bubble & jet is their most expensive "top shelf" spa. I paid close to $1300 other pay as much as $1800 depending on site and time of year! here is the A.G. form for Intex in Long Beach..https://da.lacounty.gov/sites/default/fi... or do it online here..https://oag.ca.gov/contact/consumer-comp...
SOURCE: I need filter cartridges for Intex Spa
sometimes these can be hosed off with a garden hose and reused a couple of times..
SOURCE: Please help I have a intex pure spa and it has
Intex E96 code means there is a heater fuse error , replace the fuse & your problems should be fixed
SOURCE: I keep getting a E96 code on my intex pure spa and
The code is indeed for GFCI issue.
But if you eliminate the GFCI not only is it fatally dangerous to the users of the spa. But the internal components know it doesn't have GFCI protection due to the monitoring of the Neutral conductor.
Probably had the original GFCI wired wrong to get the initial fault code.
SOURCE: We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
www.intexdevelopment.com/index.php/28401.html
Dry fire protection is when the heater has a call to heat but it is sensing NO water flow, therefore heater will be disabled.
A dry fire is when the heater comes on with NO water flow - damaging your heater beyond repair.
Causes: No water in tub, closed valves, clog restricting water flow, or the pressure/flow switch had failed?
Hi, We are having the same issue. What did you end up doing to fix it?!
