Home Logo
Question about Home
How do I set time for westclox LED alarm model 70012
Holding down T.set for 3 secs. but will not change the HOUR
Posted by Caroline Tyrrell on
timbo
I pressed ******* the time button and hit the minute button as you suggested. It worked!!!! Thank you! I have an old clock that belonged to my dad from a very, very long time ago.
Posted on Sep 19, 2020
3 Related Answers
Anonymous
SOURCE: Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off.  Switch the "ALARM" to "ON" when done.
Posted on Sep 03, 2008
Anonymous
SOURCE: Westclox Travel Alarm
After selecting either TIME, DATE, or ALARM at the top of the screen, use the stylus to touch and hold the large time display. Hold it there for about 5 seconds and the clock will beep and the time display will start flashing. Then you can touch either the hours or minutes and it will increase by either 1 hour or 1 minute accordingly. When the DATE is selected, it shows the year in the large display. Again, holding the stylus on the year diaply for about 5 seconds will enter into the chqange mode. IN all cases, to exit the change mode simply select one of the other selections across the top: TIME, DATE, ALARM.
Posted on Sep 08, 2008
Anonymous
SOURCE: Westclox model 22717
Wesclox 22717 reset problem
Searched the web but couldn't find the answer either. I was about to throw the clock away when my 10 year old son came by and said "press hard". So that's the answer! I used a pen to press the time button then hit the hour and minute and it did the reset. Good luck.
Posted on Sep 23, 2011
1helpful
I need help setting the alarm on my vintage Sanyo Model RM 5005 radio
I just brought the same one at a garage sale, after a bit of fiddling around, i figured it out
To set the time:
1. Hold down the 'real' button
2. While holding it down, push down hour until you have the desired hour (if you want pm, you need to go around until the 'pm light' is on
3. While still holding down the real button, push the minute button until desired number is reached
To set the alarm:
1. Hold down the alarm button
2. Follow steps 2 and 3 of setting the time, except with the alarm button held down instead of the real button
How to set alarm for Westclox 47550 Quartz?
Hi, A 8 year old can do this. On the back of the clock there should be 2 round turning nobs. 1 is for to set time (min...) 2sec is for to set timer for that hour...usually is a smaller hand on face of clock.
select hour to wake up at and set alarm Button. This is only basic set up.
I have a westclox 70034 and I need to know how to set the alarms
Push the alm1 alm2 button until your desired alarm number shows. Then hold the alm1 alm2 button for approx 3 seconds. The alarm time will flash. push the ADJ button until you reach the time hour you want. Then push the alm1 alm2 button to set the minutes. push ADL until you find the desired minutes. The push alm1 alm2 button and alrm will stop flashing. Your alarm is now set...... I to lost the manual and had to figure it out myself.
Dec 14, 2010 • Vacuums
84helpful
3answers
I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
11helpful
4answers
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
25helpful
2answers
3helpful
2answers
Hi faulkquarter
I take it that the clock displayed with this problem if not a 22717 model. The one I have sighted is a digital clock. Generally, you need to hold down the "time" button and also press the "hours" and "mins" buttons at the same time to set the time. If this is not how your clock appears, please give me the button names and I can write a method of changing the time for you.
regards
Graeme
Open Questions:
Top Home Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
