I have a 1993 VW Passat VR6, My problem is when I try to start it, I have no spark from the spark plugs..What could be the problem or how do I fix this?????
GO TO THIS SiTE TO CHECK THE FUSE BOX!
http://vwtech.no-ip.info/images/golf/post90.gif
This are the FUSE and RELAY number SLOT!
Fuse No. Description Ampere Rating
1 Headlight, low beam, left 10
2 Headlight, low beam, right 10
3 Instrument panel lights, license plate lights 10
4 Glove compartment light 15
5 Wiper/washer 15
6 Fresh air blower 16-valve only: Air conditioning 20
7 Taillights, side marker light, right 10
8 Taillights, side marker light, left 0
9 Rear window defogger 20
10 2.0 16-valve only: Fog lights 15
11 Headlight, high beam, left,High beam indicator light 10
12 Headlight, high beam, right 10
13 Horn 16-valve only: Radiator cooling fan 10
14 Back-up lights, washer nozzle heaters 10
15 2.0 16-valve only: Engine electronics, stabilizer valve, cold start valve 10
16 Instrument panel warning lights, 16-valve only: Multi function indicator 15
17 Emergency flasher switch, turn signals 10
18 Fuel pump, oxygen sensor heater 20
19 Radiator cooling fan, air conditioning 30
20 Brake lights, cruise control 10
21 Interior lights, digital clock 16-valve only: Luggage compartment light,multi function indicator, central locking 15
22 Radio, cigarette lighter 10
Relays
Relay No. Description
1 Air conditioning
2 Open
3 Digifant control unit
4 Load reduction relay
5 Low coolant level control unit or Open
6 Emergency flashers
7 Rear Wiper
8 Intermittent wipers
9 Seat belt warning system control unit (possibly headlight warning too?)
10 Fog lights
11 Horn
12 Fuel pump (except diesel)Glow plugs (diesel)
13 Radiator cooling fan after run (except 16-valve)2.0 16-valve: Starter interlock relay
14 Automatic trans., coolant temperature indicator,starter interlock relay (except 2.0 16-valve)2.0 16-valve: Radiator cooling fan after run
15 ABS pump relay
16 ABS relay
17 Heated seat control unit, driver
18 Heated seat control unit, passenger, or power seat circuit breaker
19 Automatic transmission
20 Open
21 Power window relay, ABS hydraulic pump fuse
22 ABS valves fuse
23 Air conditioning, power seat fuse
24 Power window fuse
I was able to fix this, believe it or not our roof was being repaired and the roofer covered up the roof top compressor (heat pump) with a tarp which must have caused the compressor motor to overheat with no air circulation??? and the roof top switch/braker tripped, when i removed the tarp and flipped the switch next to the compressor every thing worked fine again.....who knew!
