Question about ZEEPAD Brand 7inch 4gb Android 2.3 Tablet Pc, Inbuilt Wifi, Camera,
How do i get my pad to go to apps
I tried to reset and reboot.it starts and i get the android then a blank light blue screen comes up and stays.I can not send pics. or video please help.
Posted by robert on
2 Related Answers
ESGold
ESGold
  • 63 Answers
SOURCE: why isnt my zeepad pink 7.0 staying on white screen i turn it on?
So, now you've become a robot.. Throw it in the river and buy fishing pole.
Posted on Jun 12, 2014
laneycath
  • 3 Answers
SOURCE: how can i get my pad to show home page
http://www.dummies.com/how-to/content/how-to-reset-ipad-settings.html How to Reset iPad Settings Life may not have a reset feature, but iPads do. If, for some reason, you want to return your iPad to its default settings, you can reset them. The last item under iPad's General settings is Reset. When you click it, you get options for resetting the following:
  • Reset All Settings: Every one of the preferences and settings are reset, though information you've added to apps like Calendar and Contacts doesn't change at all.
  • Erase All Content and Settings: This one both resets your settings and erases information you've added to apps like Calendar and Contacts. This is useful if you plan to sell your iPad.
  • Reset Network Settings: By choosing this, any networks you've set up are removed. iPad will also turn off Wi-Fi, and then turn it on again, which disconnects you from any network you're connected to. Note that the Ask to Join Networks setting stays on.
  • Reset Keyboard Dictionary: When you turn down iPad suggestions of words as you type, you can add words to the keyboard dictionary. You do this by tapping a suggested word, which rejects it but adds the current spelling of the word to the dictionary. If you don't want to keep all those added words, use this reset option.
  • Reset Home Screen Layout: If you want to get back to the original home screen you saw when you took iPad out of its box, choose this reset option.
  • Reset Location Warnings: When you use an app like Maps that checks your location, it asks you if it's okay to do that. When you tap OK to let it proceed two times, it stops asking. If you want it to start asking again, tap this reset option.
Posted on Jan 21, 2015
How do I unlock my tablet
If it's android then you can reset it but you will lose all the apps you installed along with any saved passwords.
power off the tablet by holding down power until screen goes blank.
hold both the power button and the volume up button for at least ten seconds.it should boot to android logo...then a robot with red exclamation.leave it alone until the option to reset screen appears.
follow onscreen instructions to reset.
Jan 26, 2015 | Tablets & eReaders
How do i get my pad to go to home page
Can you get into the settings if so go to the general settings snd you should see reset at the bottom press this and the whole ipad should go back to factory settings . Don't worry about your folders and other stuff you have it wont delete anything hope this helps
Jan 21, 2015 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
How can i get my pad to show home page
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Trio 10 1 turns on but wont go past the next screen to see my apps
Press power and volume + buttons together until reset screen comes on, then select factory reset!
Nov 09, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
Start up
SAFE MODE OPTIONS
1. Press the System or Menu Button in the lower left corner and navigate to Manage apps.
2. Find the most recent app you installed.
3. Force close it.
4. Disable it if possible.
5. Remove this app.
6. Reboot the boot to see if the Safe mode is gone.
If the Safe mode label is still present, the article suggests that it may be necessary to press several keys to achieve the removal of the Safe mode label and its effect of suspending the other apps. In essence, we now move to the second discussion of entry into Safe mode:
1. Safe mode can be entered by pressing buttons at start-up. .
2. It is not known exactly which buttons were pressed but it mostly likely was the System and Home (center big button) and maybe even the Escape/Back button on the right.
3. The right combination of buttons, which supposedly are the same to enter Safe Mode, are the same to exit Safe Mode.
4. If you are certain you entered Safe Mode by accident - meaning you know you did not recently or just now installed an app that force closed Android, then you just have to find the combo to exit it.
5. Try pressing the volume buttons might clear the Safe Mode on the first reboot after initial entry into Safe Mode.
6. If the Safe Mode label disappears after pressing the volume buttons, your phone is okay.
7. If the label is still present, try rebooting the phone again.
Safe mode in Android what to do if you see that label on your screen
Apr 01, 2014 | Kocaso M1050
Google play stop working on my irulu pad, it just says no connection
you have to reset the tablet to factory conditions. i was at my wits end before i did this. o stay away from opera, firefox, and chrome there are other browsers
Nov 14, 2012 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
ZEEPAD Brand 7inch 4gb Android 2.3 Tablet Pc, Inbuilt Wifi, Camera, Logo
48 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Sean Cole
Sean Cole
Barrissimo
Level 1 Expert
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
