SOURCE: Lens stuck
If the lens is not coming out, its stuck, or it wont completely open or close, that is the lens assembly, that needs to be repaired. You need to take it to somebody, that can either repair it or replace it for you. There is nothing that can be done, other than that......
SOURCE: Lens Error!
I know this is really late, but I've been having the same problem with the S6 on and off for the whole year, and I suspected a loose part. For a whole week, I couldn't turn on my camera, and the lens cap doesn't close until five minutes later. So I did what someone should really not do to a camera- I got my lens cloth and pushed on the lens directly as the stuttering noise occured. It works! The camera now turns on and off! Right now, it works okay for a while, but I suspect it might getting weird again, so I will try pushing it in harder next time and see if that will fix it for longer. other than than, make a better choice the next time you buy a camera! =\ I hope this will help others who have the same problem. Please email me at [email protected] for any other solutions and/or comments.
SOURCE: Lens error
If it is a new[ish] purchase send it back via the seller. It may be an issue with the particular model. Get onto Pentax Tech support Team- See what happens- if it is an issue then a replacement free or at moderate cost may be available. If the camera is older -there will be no economic repair option.
SOURCE: OLympus FE-280
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the service online ++++Thanks for using FIXYA
