Question about Ranger Radio Communications
I have a ranger rci 2970n2 that needs repair does anyone know where i could send it to get fix or does anyone have ranger company phoene #
Radio turn on but do not transmit or recieve
Posted by anibal garcia on
Radio-tech155
    New Friend:
  • 38 Answers
Www.Rangerusa.com
Stay away from cb shops.. Only let the manufacturer service it.. Your 2970n2 has a fragile and tempermental amp built it with the 8x irf520n mosfets in it.. You will have problems if its tuned up to do more than 200-225 watts pep..
Posted on Jul 02, 2015
Scott Buckholz
    New Friend:
    Problem Solver:
  • 5 Answers
Https://www.theradioshop.net/
Posted on Jan 21, 2015
RCI 2970n2. What is the wiring to connect a Turner Plus 3 microphone?
pin 1 ground
pin 2 audio
pin 3 TX
pin 4 not used on other mics or has 8v on TX for powered mics
pin 5 not used on other mics
pin 6 not used on other mics
Jul 03, 2015 | Radio Communications
RCI 2970n2. How do I connect a Turner Plus 3 mike?
1. gnd
2. audio
3. tx
4,5,6 will not be used rx, ch up, ch down
Ranger rci 2950 will not transmit
have you tried it on all bands? still won't transmit?take it to a tech so they can fix it properly.
Sep 16, 2012 | Ranger Communications RCI-6900F-25 CB...
I have a RCI 2950 comes on keyed up and stays keyed untill you turn it off. I have replaced the auto amp, all voltage regulators and the black diode with yellow strip below mic plug with no change. I need...
i have the same radio rci 2950. Ive had the same problem with mine,turns out with mine the processor would lock up,turning the radio off & on repeadly would clear the problem and the radio would work fine x-mit & recieve. the solution to fixing the problem is to replace the memory backup battery this battery works similar to a computer motherboard cmos battery when this battery goes dead all sorts of strange things happen to the radio wont transmit wont recieve or like your problem transmits continiously. the problem with replacing this battery is finding out what year & model your ranger 2950 is. the internet says only first generation ranger 2950s use the battery second genration & third generation do not use the battery. but the internet could be wrong. so i suggest getting a hold of (usa ranger.com) & give them a phone call or email and ask them about the year your radio was made. they may even service it for you or if you are electronic savvy you can do it yourself. the battery is located close to the main cpu on the front panel if yours uses a battery.
Sep 07, 2011 | Ranger Communications RCI-6900F-25 CB...
Ranger rci 2970n2 radio need more modulation where is the audio limiter
AMC:
Mode to AM
Set generator for 30mV RMS, 1KHz sinewave.
With Mic gain at maximum VR14 Adjust for 100% modulation. Use modulation meter or oscilloscope with RF sampler.
Feb 26, 2011 | Radio Communications
Need user manual for ranger rci-6900f turbo
Here is a link that goes to RCI for the complete manual for this model----let me know if you have questions.
If this helped you rate this solution as I do this here for free.
SD TECH
http://www.rangerusa.com/pdf/man6900f.pdf
Dec 17, 2009 | Ranger Communications RCI-6900F-25 CB...
Ranger rci-2950
Hopefully it's as easy as this carefully take the cover with the speaker in it off and look to make sure the speaker wire with the plug is plugged into the two prongs sticking up in the back right side corner it is a very tight fit though.Good luck Dan
Aug 28, 2009 | Ranger Communications RCI-6900F-25 CB...
RCI 2950
Hello, Just offhand I'd say you have a bad solder joint on the main circuit board. Without more info, I can not tell you where to look,,,,, Mechanic
Jul 09, 2008 | Ranger Communications RCI-6900F-25 CB...
Radio Communications Logo
203 people viewed this question
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
