My windows 7 is not genuine ,how can I fix it please?
Solutions to Fix Windows 7 not genuine error:
solution 1: with the help of Command prompt of administrator mode
solution 2: By making use of Control Panel
Read more: Fix Windows 7 not genuine error
If you want to be adventurous and save some dinero you can download a pirated version of the software you want complete with the activation serial numbers. But to do this you will have to load the software and start from scratch - your files will be lost unless you back them up and re install them after the OS is loaded into your machine.
Hi D120179 - The fix for Win 7 to be genuine is to go to Start/Control Panel/Sytem icon. From there at the bottom is the Activation status. You should be able to use the Activation key you received with your Win 7. You will need to be able to connect to the internet with this computer to complete activation. Some third party distributions of Win 7 will produce an error message that Win 7 is not genuine - if it is not installed on the same type of PC as it was originally activated under. You can verify this on the system page as well under the System line - it will say the manufacturer and Model. If you do not have an activation key, you are correct it is not genuine or is corrupted. Hope this helps. Thanks.
Buy a key on the Microsoft website.That is the only genuine way.
Sorry, I know there are sites offering "non legal" key's but you can't never trust these.
