Cell Phones Logo
yossi boni Posted on Jan 20, 2015
I changed the iPhone to Samsung and currently the nesa 749 nb not find my blue tooth . What to do?
How do I send a photo from my Samsung gs7583t
iPhones do not accept data through bluetooth.
Can you e-mail it instead?
2answers
How do I connect an sbt-105 bluetooth headset to my computer(or is it even possible)?
Does your PC have blue tooth enabled? It may need a blue tooth dongle in order to see the headset
How do I fix iPhone microphone Problems with headset and Bluetooth?
Go to the settings on your I phone select search for blue tooth device and at the same time hold down the large button on your blue tooth device until it flashes blue and red keep it pressed until it stays blue then your phone will be pared to you're blue tooth device.
Mar 15, 2013 • iPhone Apps
How to play music in my iPhone 4 via blue tooth
first you must add your iphone in your blue tooth devices.
play your music on your ipnone.
go into the sync menu and make sure it is on blue tooth audio
if not change it to that and it should play.
2helpful
I have a supertooth car kit (for on the sun visor) and have turned bluetooth on, on my iphone 4 but don't know what to do now to pair them.
turn blue tooth on on your iphone under settings click general click on blue tooth make sure its on then it will auto serch the super tooth make sure its turned on
too easy let me know how you went
My parrot 3200 ls worked perfectly with my previous Samsung D900 however ive recently changed my phone to a apple 3G iPhone, I managed to connect via Bluetooth which is recognised and can make and receive...
I apologize that you having a issue with your hand-free device.
Let me see if I can address some issue with you and help you understand the reasons why your iphone is not working with your device.
Okay blue tooth comes in many flavors and many abilities.
The iphone is not fully compatible with this device and several people as yourself have complained about this issue, currently as of late there was no work around.
Now the iphone uses blue tooth that the parrot just does not fully communicate well with witch causes this issue where you can hear the person but they cannot hear you. This compatibility issue has many people upset.
Now there may be a upgrade witch I will provide a website you can go to.
http://www.justcarkits.co.uk/
Now I cannot guarantee that any said upgrade will work, I am just going by real life results so I hope the information I give here does help you understand. I also hope things goes well in trying to upgrade/update this unit to your satisfaction.
if you have any questions please get back with me.
Thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
7helpful
Blue tooth
The iPhone is supporting Bluetooth v2.0, but for headset support only.
See the iphone specification here:
http://www.gsmarena.com/apple_iphone-1827.php
That's mean it can use the bluetooth to connect only, with bluetooth headset.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
