Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Micromax canvas a 101 pattern lock open
HOW TO OPEN micromax canvas A101 HANDSET pattern lock open
Posted by GOURAB MUKHERJEE on
Christopher Goins
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 39 Answers
How to Unlock Micromax Phone Using Hard Reset Using stock recovery and wipe data. This method will result In a full factory reset of your phone . How to do this?
  1. Switch off, Pull battery.
  2. Insert battery and Press and Hold Power+Volume up+Volume down together (different phones might have a little different method of booting into recovery mode, but this is the most general one).
  3. You will then boot into recovery mode , use volume keys to navigate up and down and power key to choose.
  4. Choose Wipe DATA
  5. Choose wipe cache.
  6. Reboot device.
You are done and your lockscreen is gone and phone has been hard reset. Please not this leads to permanent removal of data.
Unlock Micromax Android Phone using Android Debug Bridge In this we will use ADB (Android Debug Bridge) to unlock the device without losing any data.
  1. First we need to set up ADB on device , you generally need these link of adbzip in the bottom or you can Google on how to install ADB in windows.
  2. Just make a folder adb in c/root and copy the files.
  3. Install drivers of your phone (Use PDAnet if you have problem with finding drivers).
  4. Turn on USB debugging on phone. Follow : Setting->Development->USB Debugging (Turn On)
  5. Open Command prompt in computer , and type cd C:/Android (Android here is the folder where my adb files are , change according to yours)
  6. Then you can try following sets of command
Adb files rar download 2shared
Posted on Jan 20, 2015
How can i unlock my micromax canvas phone without lossing my data. its urgent and i need my things badly
Try connecting your phone via USB and a data cable to a computer and copy the data from the phone and memory card onto that computer. Data on your SIM card will move when you move the SIM card to a different phone.
Another way is if you are trying to enter a pattern unlock. after inserting wrong pattern 6 to 7 times it shows a 30 seconds time limit to again enter pattern and you get a option of Forgot pattern
Click on Forgot pattern and enter your gmail id and password and the lock will then unlock see the image below. Maybe your broken screen will allow entering the gmail id and password.
Mar 19, 2015 | Cell Phones
How to open pattrn lock
put ur phone in power off mode and hold vol up and power key at the same time. den phone is on factory mode use reset factory and its take some time pattern lock is open. :-)
Feb 11, 2014 | Computers & Internet
Micromax master resetting code all
Hard Reset Micromax Canvas HD A116
  • Switch Off your phone.
  • Press and hold Power button together with 'volume +' and 'volume -' buttons on the side of phone until you get two options.
  • Now, press the 'volume +' button to enter into the recovery mode.
  • This will make a Android icon appears on screen, press power button.
  • This will get you the menu options, use the volume up and down button to choose the option.
  • To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds.
  • Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage.
Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. The hard reset procedure is same for Micromax Canvas A110 also. If you have any questions regarding the procedure to hard reset Micromax Canvas HD A116.
OR
The Instructions
  • Turn Off your device
  • Press and hold the Volume up (+), volume down (-) and power keys at the same time until the screen show the two options
  • You will get the option Recovery mode and Factory mode , to select the Recovery mode press the volume up (+), for the Factory mode press the volume down (-).
  • If you want to hard reset your smartphone, you should select the recovery mode.
  • To navigate it, you can use volume up and down.
  • To select an option, you must press the Menu button.
  • After you hard reset the device, your smartphone will return to factory setting automatically.
OR
Hard Reset:
  • Press and Hold Volume Down + Power Key for 20-30 Seconds.
  • Now you See Warning Logo on screen.
  • Now Download Android Multi Tool
  • Download fastboot driver and install Drivers
  • now open tool and press "8" and enter to wipe data / factory reset.
  • after format remove battery and reinsert battery.
  • power on the handset.
  • Download Driver from Here
  • Download Android Multi Tool from Here
Nov 07, 2013 | Cell Phones
How to unlock pattern lock on micromax A89
too many pattem attempts unlock
Apr 21, 2013 | Cell Phones
Micromax a 87 ninja superfone
Micromax a87 ninja 4 too many pattern attempts · I entered to many ... source: My micromax superfone a87 pattern locked ,pl help for unlock/ restore? Was this ...
Apr 01, 2013 | Cell Phones
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
164 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
