Question about Acu-Rite Acurite Wireless Indooroutdoor Thermometer 00606
I have 1097b and it dosen't show me the tempiture any more , was working good?
The temperature is showing just a half what ever for a temperature
Posted by gerald kerr on
I have a samsung split system it's just shows error 6 and dosen't work .. It's the perpendicular style.. Please answer my question ...
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
Aug 01, 2013 | Heating & Cooling
Some dash lights on my 01 ranger don't work.the bulbs are good
Get an Auto Electrician to trace and fix the problem. There are partial contacts in the wiring system.
Dec 29, 2012 | Ford F-250 Cars & Trucks
My tv showing green picthure
Check if the SIGNAL CABLE is connected PROPERLY. Dosen't help?
CONTACT your OPERATOR. HOPE THIS HELPS.
Sep 08, 2012 | Televison & Video
How to change from ºF to ºC on the UMC-117?
According to the 2012 manual, 'the LED display only shows F.'
Bottom page 65. Yet the F temperatures are also shown as C in the manual.
http://waterheatertimer.org/pdf/How-to-set-Rheem-tankless-temperature.pdf
You probably have different model, or older model?.?
Older manual (page 15) shows same temperature range with both F and C, but typical of Rheem, the manual is totally vague about settings and say that qualified tech needed to adjust temps beyond factory default range (with no mention of display showing C) ... which is safeguard since the damg product cannot always heat water fast enough to reach higher set points above 120F.
http://waterheatertimer.org/pdf/TanklessOutdoor_95_84_64X_UC_AP15318.pdf
Call Rheem 800-432-8373 and give your product serial number and model number located on side of unit, and ask them.
Don't forget to keep the product maintained to avoid common error codes.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 28, 2012 | Rheem Tankless Water Heater Main Remote...
I replaced the brake pads on my 2006 325i and the service light still stays on and dosen't show for how many miles those pads are good for
Try turning the key on to the run position and leaving it there for about 90 seconds before starting the car. That was how we reset the brake wear indicator on the e36 model so it may work the same on the e46.
Aug 16, 2011 | 2003 BMW 325
Lookin for the coolint tempiture sending unit on the motor in a 140 volvo excavator
Don't know your rig but most coolant sensors are near the inlet to the radiator and that is located at the bottom tank. They don't measure the engine temperature but do sit in the coolant stream as described.
Apr 21, 2011 | Volvo 240 Cars & Trucks
Acu-Rite Acurite Wireless Indooroutdoor Thermometer 00606 Logo
67 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
David Gust
ray gallant
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
