Question about Jura Capresso Impressa F7 Espresso Machine
Hi Our Jura Impressa F7 keeps saying " Open switch" then " Rinsing system" continuously. Please help what do I do?? I have rinsed the system several times.
I have restarted the machine. I have tried warm water in the Water tank.I have switched it off for a day. I have tried pushing other buttons , but It will not allow me. Please help.
Posted by Tasmyn Wyman on
Kolbrun Gunnarsdottir
  • 1,215 Answers
Good evening
I would look in the troubleshooting pages in the manual.
here you can take a look, Kolbrun
Free User Manuals and Owners Guides ManualsOnline com
Posted on Feb 02, 2015
3 Related Answers
Tushar
  • 9 Answers
SOURCE: My Jura Impressa xs90 keeps stating fill system,
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
Posted on Oct 16, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Jura Impressa F7 rinse will not push water through the heads.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 15, 2010
Anonymous
SOURCE: jura impressa f7 decalcifying pressed rinse but
First you have to turn the machine off and then press and hold rinse buttom until you read empty tray and then follow the rest of the instructions. Good luck
Posted on Jan 19, 2011
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
I have a Gaggia Syncrony Compact machine which I am trying to descale. I have added the descaler to the water in the tank. when you hold down the button (26) more than 5 seconds nothing happens.What is the...
To descale the appliance proceed as follows:
• Mix the descaler with water as specified on
the package and fill the water tank.
• Switch ON the appliance with the ON/OFF
switch (7).
• Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
I noticed you did not mention the switch ON before you pushed button 26. Try that should work.
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
How to descale machine-is there a video showing how? I have the Saeco Magic Comfort + machine.
Hi
I put this next statement in so your machine will last longer.
Enter the menu by pressing the menu button. Scroll down until you reach "water hardness" and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to "Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Feb 14, 2011 | Saeco Magic Comfort Plus Espresso Machine
The water will not preheat. I turn on the switch, but it never goes off and the water remains cold. How can I fix this?
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won't heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Jan 27, 2011 | Rancilio Silvia Espresso Machine
The light on my rancilio silva expresso machine does not go on and the machine does not warm up. Last night it was fine - this morning dead. It appears that either the switch has gone or something else is...
There is also a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won't heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Dec 11, 2010 | Rancilio Silvia Espresso Machine
I have lost manual so i am trying to find out how i descale my machine
Hi
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Jun 18, 2010 | Saeco Magic Comfort Plus Espresso Machine
How do you descale a Saeco Magic Comfort Plus coffee machine? do you buy some fluid from somewhere and pump it through or what?
Hi
Jun 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
We dont have a manual for our Saeco Magic comfort coffee machine and the declcify message is up on the screen. What do we do?
Hi
Enter the menu by pressing the menu button. Scroll down until you reach “water hardness” and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to “Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process andwhen it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to “reset descale”, push the enter button and chose “Yes” and push the enter button. Now it will tell you we next to be descaled.
Apr 20, 2010 | Saeco Magic Comfort 103467 Espresso...
MY SILVIA NOT WARMING THE WATER. I LEFT THE MAIN SWITCH "ON" AT STEAM FUNCTION WITH THE SCREW-KNOB OPEN AND THE STEAM SWITCH "OFF". TOMMY.
Hi
If your lucky.
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also an other problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Dec 22, 2009 | Rancilio Silvia Espresso Machine
Water light blinking
ok you have a priming problem
press the warm water button and open the valve . Normally that should prime it.
Other wise you have in the box the primer tool of saeco.
Just press the button and push the water in after opening the knob. http://cerinicoffee.com/Saeco_User_manuals_free.asp
give you details.
Apr 07, 2008 | Saeco Incanto Classic Espresso Machine
Jura Capresso Impressa F7 Espresso Machine Logo
1,531 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
