Question about Tablets & eReaders
I need to charge my tablet using usb port, but it only charged to 43% then started discharging. It is down to 30% How do I charge it to 100%?
Something is wrong with the regular charging port so I am using the USB port and have it plugged into my computer. The icon on the tablet shows it is charging but the charge has gone down from 43% to 29%.
Posted by Secret Agent on
Tom Chichester
    Top Expert:
  • Tablets & eR... Master
  • 55,379 Answers
The battery may be unable to charge completely.
Posted on Jan 19, 2015
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
How do you use a USB cord to charge a azpen 13.3 when the normal charging way is broke
I don't think you can. The USB port is meant to go out of the tablet and the charging port brings the charge in. Unless the Azpen is different from many other tablets.
Mar 19, 2015 | Tablets & eReaders
Will my zeepad charge threw my pc. charge light has come on but zeepad has not
You cannot use a computer USB port to charge a tablet, unlike charging a smartphone. You will have to use the supplied charger. If you really want to use the USB port to charge your Zeepad, you will need to custom-built a cable using any extra USB cable you can spare. Just change the connector at the remote end of the cable to one that suits your Zeepad's 5V DC IN socket. You are forwarned the connector is not easy to find.
Jan 12, 2015 | Red Tablets: Zeepad 9XN Dual-Core 1.5GHz...
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
Aug 04, 2014 | Tablets & eReaders
How can I get my Zeepad Android to stop shutting down on start up?
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
May 10, 2014 | Tablets & eReaders
Battery won't charge
Yes it will :)
If you are using a USB port on a PC or Laptop think of trying a different USB port - sometimes they put out low power;
If your laptop or PC is more than 3 years old it probably can not put out enough power on the USB to charge a tablet (any tablet).
Check to see if any of your existing wall adaptors for (say) your phones have the same micro USB connection - use it to charge your Kindle - it's totally fine.
Go to any shop in the high street and buy a Micro USB wall adaptor, they start at about 5gbp. You can get them on Amazon too.
Remember it takes about 6 hours to charge from the wall and 16 hours (yes, 16) to charge from a computer usb.
Good luck
Feb 17, 2014 | Amazon Kindle Fire HD
Archos arnova refurbished 7k G3 tablet frozen on ARNOVA screen
i had same problem with my gadget,i replaced the battery.and have it checked to make sure no reformattingg needed
Feb 04, 2014 | Archos Tablets & eReaders
Kindle isnt charging
Yes it will :)
Good luck
Feb 01, 2014 | Amazon Kindle Fire HD
Tablet won't stay powered with out being plugged in
I have seen this several times now. It is usally do to 1 or 2 things that you can try to resolve this. The first issue is that these tablets are very battery eaters and you need to charge it for atleast 24hrs with power cable before you activate it. The USB cable will only keep the tablet charged if u have a good 50precent charge in it first. I have had the WI FI discharge a full battery in 2hrs plug in to the usb. The power adpter needs to be used when u can or it will discharge the batt unless u power down the unit not just let it go to sleep.
Go to the settings tab..then to battery..and u can see what the rate of discharge is ..ie..wifi and wallpaper and idle all can be adjusted to max battery life and make sure you turn it off when u can.
Hope this helps.
Chad Man
Sep 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Tablets & eReaders Logo
129 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
