Question about Tablets & eReaders
Fix no connection retry error
When i try to update tablet it won't when i try to install apps it won't i've done a factory reset and still does the same my wifi is connected fine on all my other devices but not onmy tablet
Posted by Alice Gutsche on
Harrie
    Top Expert:
  • Tablets & eR... Master
  • 6,740 Answers
Then firs setup the WiFi connection to the tablet. Don't assume it will work automatically. Use the known connection and give in the correct password. Wait till it confirms the connection is there.
Posted on Jan 18, 2015
Mike
    Scholar:
  • 190 Answers
Sounds like your wifi is turned off. Go to your wifi settings and make sure its on. This is a common mistake for most of tablet users.
My granddaughters contixo tablet will not connect to google. I have factory reset it and nothing works. How do I get it to connect?
is there an error message? make sure you are connected to WiFi then try to update the google services mannually.
Go to Settings > Security > unknown sources enabled it. This just allows you to install apps from outside Google Play. Google Play services 11 9 51 APK Download by Google LLC APKMirror
Make sure you download the Google Play Services APK from link, then install it. Your tablet must be Android 4.0 and above. how this helps. please reply.
Feb 06, 2018 | Contixo Tablets & eReaders
Just factory reset tablet and now it is coming up google key board not working any advise
Make sure all the updates are done on your tablet. If Google keyboard is showing as an app, try removing it. Then reinstall it.
Jan 02, 2015 | Tablets & eReaders
How can I Install or update Android software on my tablet?
Hi Faisel,
Look for the PLAY store icon and find the App you want installed there. Look for this icon on your tablet:
You can also try to use the browser to initiate this to start up, use this link:
Google Play
Hope this helps!
Nov 16, 2014 | Tablets & eReaders
Android System Recovery
Obvious question is what the tablet had been doing during its' last use.
Was something newly installed, was system or apps updated, etc. ?
Were all the APPs and or system shut down properly ?
Did update or installation recommend restarting system, prior to use ? Were multiple installations / updates performed ?
Your device appears to be in a recovery boot-loop.
As stupid as this may sound ...
Is the power adapter connected ? Let battery charge for at least 30 minutes and try again.
If battery is low, it may not complete the reset. - you should have seen something on the screen, denoting " wipe and reset " procedure and completion - prior to (#1) Rebooting device
Per your post, you have already (#4) wiped the data and instructed the device to reset to factory settings, then (#1) Reboot system.
That is the generally accepted reset method
This problem is not all that uncommon, it generally results when attempting reset, internal boot commands error for what ever reason. ( can not find the factory restore / recovery file set ).
This problem is more common when "fixes ", Specialty " Roots " or "mods" have been installed by the user - making changes to the boot program and commands OR when manufacturer files have been deleted / moved from system access. - Common suggestion is to work backwards through the mod processes and / or attempt to re-install mod or follow the special mod recovery method.
Without having available the proper ROM " flash " update / installation file(s), and you may " brick " the device.
I recommend you go to manufacturer site and check for available ROM files, reset / reinstallation processes ( memory card method ? )
You state the tablet is less than six months old. You may want to contact manufacturer for possible warranty service.
They will most likely ask the referenced obvious questions, to better understand the cause / nature of the device failure and recommend the best immediate possible solution.
This may not be what you seek, I hope it will provide better direction.
Apr 20, 2014 | Hannspree SN10T1 101 Tablet
My apps continuously stop and I have factory reset numerous times to no avail on my apex ap7s118 plz help me with this problem
Hi.. by going to task manager u should have to clear the previous opened apps.. so that apps are running in background.. so u have to close it every app.. or
Update the Definitions for OS.. then the problem will solve..
Apr 06, 2014 | Tablets & eReaders
I dis a factory reset on my Proscan 8 PLT8235G tablet. Now, I can't install or update any apps. What do I do to fix this?
Not being able to update any apps simply means either you don't have access to the internet or that your apps update is programmed to function ONLY when you are connected to/through WiFi.
second, you can download standalone 'raw' apk files online and install on your tab.
Remember to go into your Settings---Security (and under Device administration, check 'Unknown sources' and activate 'allow installation of apps from unknown sources'.
Done.
This is safe.
Post update or feedback please
Mar 06, 2014 | Proscan 8 4GB Android 4.1 Tablet
When I try to download an App, I get an ERROR that says: Error retrieving information from server. [RPC-S-5:AEC-0]. How can I get this to download apps?
Fixing RPC:S-5:AEC-0 Google Play Store Error
The Google Play / Android Market error retrieving information from server RPC:S-5:AEC-0 error message can be a bit of a pain, the RPC:S-5:AEC-0 error just randomly appeared on my tablet after it upgraded to a newer version of Android. However this is how i managed to fix the RPC:S-5:AEC-0 error with ease.
  1. Load the Settings app, click apps, then select "All"
  2. Next in the all apps view find the "Google Play Store" and click on it
  3. Now click "Clear Cache" (Not Data), then Force Stop.
  4. Next in the same app list find "Google Service Framework"
  5. Click clear data (Not Cache), then Force Stop
  6. Switch off the phone or tablet and turn it back on
  7. You should be able to download and update apps from the Google Play store once more.
Enjoy no more RPC:S-5:AEC-0 errors when downloading or updating apps.
Or Simply Go to settings/app.manager/all
Delete data + cache :
Google Play Store
Google Play-services
Google Services Framework
Hangouts
Market-feedback agent (important)
Then delete google-account(data/system/user/0/ fine the accounts.db file and cut and paste it somewhere else)
Restart the phone and then re-add google-account( paste your accounts.db file earlier to it's original location).
p/s~Your device need to be rooted to remove/delete google account without a factory reset.
enjoy and have a good day :)
Oct 15, 2013 | SVP Tablet PC Android WiFi A13
Tablets & eReaders Logo
116 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
