Motor PERKINS serial n 4000
The IPC detects a loss of serial data communications from the BCM.
Fuel Gage
When the fuel level is less than 14 percent, the low fuel indicator illuminates.
The instrument panel cluster (IPC) displays the fuel level as determined by the powertrain control module (PCM) or the engine control module (ECM). The IPC receives a serial data message from the body control module (BCM) indicating the fuel level. The fuel gage defaults to E (empty) if:
The PCM/ECM detects a malfunction in the fuel level sensor circuit.
Odometer
The instrument panel cluster (IPC) contains a season odometer and a trip odometer. Momentarily press the trip/reset switch in order to toggle between the season odometer and the trip odometer. Press the trip/reset switch for greater than 2 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The odometer is calculated and stored electronically in the body control module (BCM). The BCM uses the vehicle speed information from the powertrain control module (PCM) to calculate the odometer. The odometer displays 'error' if an internal IPC memory failure is detected. The IPC stores a backup copy of the odometer value incase the IPC stops receiving a valid odometer value from the BCM.
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed based on the information from the ECM/PCM. The IPC receives the vehicle speed information from the BCM via the serial data circuit. The speedometer defaults to 0 kmh (0 mph) when the following occurs:
The powertrain control module (PCM) or the engine control module (ECM) detects a malfunction in the vehicle speed sensor circuit.
The IPC detects a loss of serial data communication from the BCM.
