Measuring Tools & Sensors Logo
I need a manual for Honeywell Atomic Clock wireless weather station Model # TE322W-EL-NL
I need the manual as it only came with a pamphlet and that was years ago.
Bruce Meyer
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jan 18, 2015
Bruce Meyer
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
12670
Points
55
I did a search and could not find anything on that particular model. But I found some things that may help.
Here is a link to a manual for a different weather station by Honeywell that may help. http://www.honeywellstore.com/store/images/pdf/TE242ELW.pdf
If not try their support section:
https://honeywell.com/Pages/contact-us.aspx
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Changed batt now how to set time
https://www.sharpusa.com/CustomerSupport/ProductDownloads
Find and download you manual for the instructions
1helpful
Ho do I change the time zone on the Honeywell TE653W-EL Atomic Clock?
press mode so that the day of the week is displayed. then hold the up arrow key on the front for at least three seconds
6helpful
Acu-rite atomic clock squeaks periodically, why?
I had the exact same problem, and found the answer on the Chaney Instrument FAQ page. There's no real solution, but here is the explanation:
Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit’s ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Nov 10, 2009 • Watches
6helpful
Honeywell atomic clock te211w-el-nl
Here is the link for the manual; http://www.honeywellweatherstations.com/Manuals/TE211W-ENG-15-3-05.pdf Hope this helps :)
Top Honeywell Measuring Tools & Sensors Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
