HP iPAQ rx5935 Travel Companion Pocket PC Logo
Posted on Jul 07, 2009
Won't get through blue HP startup screen.
Since yesterday my Ipaq rx5935 won't get past the blue HP startup screen. Tried hard and soft reset. Windows Mobile won't startup.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2481
Points
5
Try taking battery out for 6hours then reinstall and hard rest.
this works on mine. bob
2answers
So i have a Nobis tablet and i cannot get it to go past the screen that says go on it is there a way that i can fix this or is it just trash.
Hi Austin.
You could try a couple of things here.
1.Hit volume - and power button then click on wipe data/factory reset then click on yes.
2.Read more: My Nobis tablet won`t get past the startup (Nobis) screen? - It used to start up, I have only had it for 5 days, and now all of a suddenly yesterday it won`t go past that, and I can`t figure out how to do a factory reset that will work. :: Ask Me Fast at https://www.askmefast.com/My_Nobis_tablet_wont_get_past_the_startup_Nobis_screen-qna7953703.html
2helpful
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
I have an Ipaq 2410. For some reason when I turn it on all I get is the welcome screen and am asked to align screen. When I tap the target nothing happens, if I keeping tapping it may move to the next...
why own a Ipaq, and not buy a dirt cheep used android phone.
most of these devices are dead now and trash cannned
most have bad batteries,
it has no value, used and way less broken.
but do ask on the real form , called HP.com
the posts there are old and stale.
for sure spend cash to fix , obsolete, is not good.
$200 fix a $2 portable>?
here is the read place.
called HP.com
ask here.
https://h30434.www3.hp.com/
I was trying to update the Bios when my pocket pc went to a screen that has the word "Serial" at the top, a hp blue logo in the center with the word invent underneath it and at the bottom it has a v1.08. I...
Not a problem it happens just go to hp.com download the bios driver and use it on windows xp it will not work with anyother windows and run it with your ipaq connected to the pc. This will reinstall the complete bios software and bring it back to factory.
3helpful
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Hp pocket pc.Travel companion,turns on,but can't view anything
I don't know how long you've had that unit. So the question is have you done any updates on it since you've had it.
An update most likely will fix most problems.
Follow this link to get to your devices' support page. It would be a good idea to bookmark it and register so they can send you any needed update alerts for your iPaq.
10helpful
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
To perform a factory reset and return your HP iPAQ to factory settings:
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
IPaq won 't respond to screen calibration.
So far no fixes. It's just been collecting dust. I think it's a screen response issue, and will probably cost more to fix than to replace (at least for me) in my situation. I'm thinking iPhone....
Ipaq h3835 froze
Try a soft reset first to allow programs to terminate, then try to delete programs, if that fails to work give the hard reset another try http://www.fixya.com/support/p389721-hp_ipaq_h3835_pocket_pc HP iPAQ H3835 Pocket PC Troubleshooting, Support, Repair & Service
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
