Question about TCL L32D20
Can water enter the LED tv through the area where the antenna is secured to the tv? The tv is a 24in TCL. If it can, will it cause the tv to come on but not register any channels?
I have given it out to a repair man who said that the main board was damaged and he has to replace it. He purchased the main board and now the screen is white and he is saying another board in the tv is also damaged and that has caused the scree to not come on. When he got the tv it was just flicking from one channel to the next but not selecting any
Posted by Devin Saunds-Dunkley on
charles chandler
    Master:
  • 530 Answers
Buy a new tv
Posted on Jan 18, 2015
Testimonial: "Thing is I took the tv out on hire purchase and I am of the opinion that the damage to the tv was not due to water entering it because the angle of the antenna cord attachment on the back of the tv could not permit water to enter through that tiny hole where the cable cord needle enters. The tv was ok up to the night and in the morning it started to just flick through the channels and I took it in to the shop. They gave it out and according to a technician said it had signs of water entering and damaging the board and I was asked to cover the cost of it. I decided to do it and then after being carried around the bushes for months (while still paying the installments) I am told that its not the board that was damaged but the screen not good and they are not taking it on. I took them to the consumer affairs commission and since then they have called me to say that the technician said the board that is attached to the screen is damaged. I have another tv of a similar brand right where that one was, using the same antenna/cable cord and we have had terrible rains and nothing has gone bad, plus the tv that was there was before the one am having issue with was there for over five years was the big back Sharp tv and no water has entered that one and yet the back was only covered by a case with lots of line spaces. I just want to know if what they are saying is possible so telling me to buy a tv doesn't answer my question, I am dealing with a matter of principles here"
Sony DVD/VHS player to my TCL Roku TV
You can use the RCA style jacks, Yellow for video White for left and red for right audio OUT . Connect the TV end the same way. Note the source input number on the connectors of the TV. Turn both the TV and the Sony on. On the TV, select the input number the cables are connected to and you will see the Sony . If there are no unused places on the TV to connect to then take off the antenna/ cable wire off the TV and put it on the ANT IN connector of the Sony. Obtain a jumper cable wire long enough to reach the TV from the Sony and select either channel 3 or 4 whichever channel is not used in your area on the back of the Sony. Now turn both on and select TV as the source and put it on channel 3 or 4. Now turn off the Sony and change the channel on the TV to any other one in your area. If there is no picture, then the Sony will have to be on while watching TV.
Sep 15, 2016 | TCL 40FS4610R 40-Inch 1080p 120Hz Smart...
How to unlock tcl led tv
Locklear digital Television is by Antenna or cable co-axle services thru Time Warner Cable
Feb 12, 2016 | Televison & Video
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
How do i connect my Acer Aspire one D270 with TCL LED TV 40. When i connect my laptop through HDMI port screen blinks but nothing shows on LED TV .LED TV just says not supported.My laptop Graphic is I
Have you checked the settings on your TV Malik? You usually need to go to settings on there and bring up HDMI. For example, if you have TV selected on the settings, you need to change to HDMI to view stuff on your TV screen from the laptop.
Dec 10, 2014 | Acer Aspire One D270-1865
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
How can i secure firmware update for TCL TV model number L39E5000F3D?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procedure to many popular brand TVs are given.
Aug 11, 2014 | TCL 39" Class - LED - 1080p - 60Hz - HDTV
Tcl led hdtv won't program with comcast remote
If Comcast does not list a code for your TV, your remote probably does not have a code in its library that will work.
Jan 25, 2014 | TCL 50 Class LED HDTV - 1080p, 1920 x...
TCL L32D20 Logo
67 people viewed this question
Top TCL Televison & Video Experts
john h
Andrew Taylor
Andrew Taylor
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
