Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
z
z rukowski Posted on Jan 17, 2015
What could be causing my chainsaw to die after about 5-10 minutes of heavy use, starts ok but bogs untill it cools down, runs well untill it gets warm again. outside temp now is about 5-10 degrees F
chris l2
Level 1:
  • Contributor 46 Answers
  • Posted on Jan 17, 2015
chris l2
Contributor
Level 1:
Answers
46
Questions
0
Helped
22355
Points
56
I've had similar on a Husky which went on to break a piston ring. Turned out to be a combination of 2 things. The exhaust nuts were lose allowing extra heat to get to the cylinder and the fuel mixture was too weak in terms of oil. First check you're using the correct fuel to oil 2 stroke mixture it does not hurt to add a little extra oil, I suggest trying 40:1 rather than 50:1. Then check the tightness of the exhaust bolts. If they take any tightening then you will probably find you need a new exhaust gasket. Replace if necessary but make sure you tighten the exhaust and re-check the tightness regularly!
4answers
My new poulan will start and run great for about 5-10 minutes then will just quit running. let it set and cool down and it will do the same thing why?
important to use correct oil and mix. no guessing. too much oil mix fouls up the engine. make sure blade is adjusted properly and not gummed up with oily debri
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
My 97 Bonneville lost power while I was driving about 55. When I tried to give it some gas it just bogged down more...it suddenly started running good but only for a few seconds then back to the bogging...
Exhaust leak causing the PO131 & lean condition
Evap leak causing the lean condition
Two lean conditions that can't be controlled
until you fix all the issues
Chainsaw cranks and runs but after minute or two it dies. will start again but dies when trying to throttle up
Check the fuel tank vent. Does the saw leak fuel when laying on its side.? Faulty vent can cause the saw to bog down when running
1helpful
Starts and runs fine, about five minutes then sputters and dies. will not restart until cooled
do cold comp. test if below90psi remove muffler and inspect piston cyl. wall for scroing
1helpful
2answers
I have an old stihl 020 av chainsaw, the problem I'm having is when you start it and it's running the as soon as you go to give it gas it want to bog out and die even if you just try to give it alittle gas...
Look for your choke lever and make sure that it is operating properly. When the engine is choked, the butterfly valve in the engine is across the opening, causing the engine to take less air, and more fuel. As the engine begins to warm up, there is less need for the choke to be closed. If your choke valve is remaining closed, the engine will die when you pull the trigger.
Best regards, --W/D--
Jan 31, 2011 • Garden
Chainsaw runs great for about five minutes then dies wont start until it cools off
Have you tried a new spark plug??
Ensure all cooling fins are clean.
Sounds like its getting too hot.
I assume you have the correct fuel / oil mix??
Lastly a fault in the carb but you mest have all the aboce corrected before going to carb strip down.
Jan 08, 2010 • Garden
2helpful
2answers
Ryobi BC 30 trimmer bogs down with throttle
some have to warm up, although there should be a gas/oil mix screw on the carb try adjusting it
1helpful
Loss spark
Hi
You need to replace the coil but first try to change the sparkplug and see what is happening.
best regards savumihai71
Top Makita Garden Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Makita Garden Expert? Answer questions, earn points and help others
